eliminating noise at high ISO
eliminating noise at high ISO Byram 05 Jun 02:45
  eliminating noise at high ISO Frank Gore 05 Jun 04:11
eliminating noise at high ISO Kevin Brubeck Unhammer 06 Jun 10:59
eliminating noise at high ISO Kevin Brubeck Unhammer 06 Jun 11:15
2011-06-05 02:45:10 UTC (almost 14 years ago)
My D3000 does a pretty lousy job at 800 and 1600. I've tried playing with some of the tools recommended in Goelker's "GIMP 2.6 for Photographers" but didn't really see any noticeable improvements. Also tried using the wavelet denoise in UFraw. I downloaded a wavelet-denoise plugin and that seems to work a little better. All tools were used on the single RGB layer.
Any recommendations would be appreciated (aside from upgrading my camera- LOL) as I have a great but grainy shot of a Racoon at ISO 1600 that I'd love to print.
Frank Gore
2011-06-05 04:11:35 UTC (almost 14 years ago)
I do all my de-noising outside of Gimp, using either Digikam or a specific tool for the job (ie. Noise Ninja for Linux, which is commercial). For the most part, I've found all noise reduction plugins for Gimp to be lacking, especially for professional photography.
The only exception would be GMIC, which has the potential to be an amazing noise reduction tool. It's like the Swiss army knife of Gimp plugins. Specifically, Anisotropic Smoothing in the Enhancement category can generate some outstanding results. Problem is, the options are so numerous and arcane, I can't make heads of tails of them. I've wasted tons of time adjusting options blindly until I was happy with the results... but then I couldn't figure out WHY the settings worked, so I couldn't really reproduce them reliably. Maybe you'd have better luck with it:
http://gmic.sourceforge.net/
-- Frank Gore
www.ProjectPontiac.com
Byram (via gimpusers.com)
2011-06-06 10:59:29 UTC (almost 14 years ago)
Frank Gore writes:
http://darktable.sourceforge.net/ also does some noise reduction, if you have the RAW file, don't know how well it works, but if you haven't tried darktable yet, you should :-)
-Kevin
2011-06-06 11:15:23 UTC (almost 14 years ago)
Frank Gore writes:
It's rather hard to find _simple_ tutorials for G'MIC, but see e.g.
https://jcornuz.wordpress.com/2009/02/07/gmic-next-gen-greycstoration/
-Kevin
