Question on Layer Blending Modes
Question on Layer Blending Modes kevin gilbert 18 May 23:09
  Question on Layer Blending Modes David Gowers (kampu) 19 May 04:30
kevin gilbert
2011-05-18 23:09:10 UTC (almost 14 years ago)
In the section "5.8 Practical Uses of Blending Modes" of the book "Grokking the GIMP" (see, e.g., http://www.dig.cs.gc.cuny.edu/manuals/Gimp2/Grokking- the-GIMP-v1.0/node57.html ) there is an example of how to use blending modes to alter the colour of a cat.
Specifically, I refer to Figure 5.29(a) where the re-coloured cat does not appear to sit naturally on the person's shoulder (cf Figure 5.26(a)).
How can the defect be overcome? Would feathering the selection help? But would the bucket fill also be feathered?
Cheers, Kev
2011-05-19 04:30:25 UTC (almost 14 years ago)
The defect arises from:
1. use of the Color layer mode (which, until recent versions of GIMP, was a fairly inaccurate way of recoloring anything. particularly, it performed quite poorly at maintaining similar perceptual brightness.). A better alternative might be the Color layer mode in more recent (2.7+) GIMP versions, or the LAB color mixer found in G'MIC
2. Failure to consider radiosity (the coloured light which is reflected from the shirt to the cat, and the coloured light that is reflected from the cat to the shirt. If you change the color of one part of a photo, you will need to adjust the surrounding objects to appear to reflect the right color.
3. Quite frequently also the new colors are poorly chosen, so that it mismatches the overall lighting conditions. You need to ensure that the recoloring matches not only in perceptual brightness, but also in vividness: the apparent vividness of an object is heavily limited by the lighting conditions
4. Lastly, the actual shape of the mask you are using to mark which pixels count as 'cat' for purposes of recoloring; merely selecting those regions which seem to clearly be cat regions results in an area that is too strongly defined.
You can sometimes get away with using feathering, if the object is not particularly in focus. The rest of the time, some edges need to be fuzzy and some need to be crisp (basically in relation to their angle to the light.)
