move brushes between machines
7 of 7 messages available
move brushes between machines Helen 05 Apr 13:32
  move brushes between machines Patrick Shanahan 05 Apr 13:53
   move brushes between machines Helen 05 Apr 14:12
    move brushes between machines Patrick Shanahan 05 Apr 16:11
move brushes between machines Kevin Brubeck Unhammer 05 Apr 19:16
  move brushes between machines Patrick Shanahan 05 Apr 19:23
move brushes between machines Helen 05 Apr 21:42
Helen
2011-04-05 13:32:00 UTC (almost 14 years ago)
I bought a new computer - still have access to the old one through ssh. The old computer running suse11.3 has many gimp brushes that I made. New computer running suse11.4, gimp 2.6.11 How can I get my brushes (the ones I made) over to the new computer/new Gimp?
If ssh is not the best way, I can also get into the old computer gui-ly with ssh -X
Thanks for any help!
Patrick Shanahan
2011-04-05 13:53:03 UTC (almost 14 years ago)
* Helen [04-05-11 09:33]:
Your brushes are under ~/.gimp-2.6/brushes
use scp/mc/dolphin/krusader/... to copy them to your new install at: ~/.gimp-2.6/brushes
or another local directory and make sure that gimp --> edit --> preferences --> folders --> brushes points to your chosen destination.
assuming you have gimp-2.6 on your 11.3 install.
Helen
2011-04-05 14:12:22 UTC (almost 14 years ago)
Patrick,
The old machine has gimp 2.6.8, the new one is 2.6.11. And I'm a little over my head here. I assume scp/mc/dolphin/krusader/
is not the actual command but rather some suggested options. so maybe something like, from old machine scp ~/.gimp-2.6/brushes >
no, that would copy the file onto itself... I guess I'm more than a little over my head. But you've told me where they are and that's a good first step.
H.
with
ssh -X
-- (paka)Patrick Shanahan Plainfield, Indiana, USA HOG # US1244711 http://wahoo.no-ip.org Photo Album: http://wahoo.no-ip.org/gallery2 http://en.opensuse.org openSUSE Community Member Registered Linux User #207535 @ http://counter.li.org _______________________________________________ Gimp-user mailing list
Patrick Shanahan
2011-04-05 16:11:33 UTC (almost 14 years ago)
* Helen [04-05-11 10:15]:
Patrick,
H.
with
ssh -X
scp = secure copy
mc = midnight commander
dolphin = dolphin
krusader = krusader
scp --help or man scp
will explain scp
scp user@192.168.1.3:/home/user/gimp-2.6/brushes/brush1 \ user@192.168.1.5:/home/user/gimp-2.6/brushes/
would be easier for you to ssh -X ... and use dolphin or krusader
> Helen Etters
> using Linux, using openSUSE11.0
2011-04-05 19:16:30 UTC (almost 14 years ago)
Patrick Shanahan writes:
Patrick,
H.
Or just copy over the whole brush directory to the machine you're on, with the -r option, e.g.:
scp -r username@192.168.1.3:~/gimp-2.6/brushes ~/.gimp-2.6/
(this will overwrite brush files with the same name on your local machine)
-Kevin
Patrick Shanahan
2011-04-05 19:23:39 UTC (almost 14 years ago)
* Kevin Brubeck Unhammer [04-05-11 15:19]:
to bypass the overwrite situation, copy the present brushes directory to another place and replace it after the transfer.
Helen
2011-04-05 21:42:31 UTC (almost 14 years ago)
Thanks everyone! I got the brushes moved. In the end, I decided on the gui method -- but I learned
a lot from reading each of these.
Thanks! Helen
On Tue, Apr 5, 2011 at 3:52 PM, Bertrand Denoix
ssh -X
Copy the contents of ~/home/.gimp-2.6/brushes to the same place on the new. But you can also copy the whole ~/.gimp-2.6 to bring other stuff you have created or downloaded over time: patterns, scripts, plugins, filter options...
