fontconfig and gimp
fontconfig and gimp johan 11 Apr 20:18
  fontconfig and gimp Manish Singh 12 Apr 00:59
   fontconfig and gimp johan 12 Apr 17:53
    fontconfig and gimp Sven Neumann 12 Apr 19:40
johan
2004-04-11 20:18:43 UTC (almost 21 years ago)
fontconfig and gimp
I have something weard : i just installed gimp 2.0, once tried from .deb, once from source. When I open gimp i receive the following message :
gimp message : fontconfig version too old, The GIMP requires fontconfig version 2.2.0 or later.
Installed fontconfig version is 1.0.2.
Somehow you or your software packager managed to install The GIMP with an older fontconfig version.
Please upgrade to fontconfig version 2.2.0 or later.
This is really strange, since i have version 2.2.2 of fontconfig dpkg -l fontconfig
ii fontconfig 2.2.2-2 generic font configuration library
Anybody has an idea ? (I have Xfree4.2.1) Greetings,
Johan
Manish Singh
2004-04-12 00:59:16 UTC (almost 21 years ago)
fontconfig and gimp
You have more than one fontconfig library on your system. The debian one is in /usr/lib, you likely have another one in /usr/X11R6/lib or /usr/local/lib. You can run ldd on the gimp binary to find the path of the library it's using.
This message has been improved for 2.0.1 to clarify this situation, because it seems quite some number of naughty people don't keep track of what they installed on their system by hand..
-Yosh
johan
2004-04-12 17:53:56 UTC (almost 21 years ago)
fontconfig and gimp
Sorry being naughty :)) But the only thing I had to install by hand was xfree 4.2.1 and apparently here a different library has been used. Appaerently the new fontconfig is installed in /usr/x11r6/lib and the one installed bij xfree in /usr/lib. Can I fix this with symbolic link ?
Greetz, Johan
spin:/home/johan# ldconfig -p | grep fontconfig libfontconfig.so.1 (libc6) => /usr/X11R6/lib/libfontconfig.so.1 libfontconfig.so.1 (libc6) => /usr/lib/libfontconfig.so.1 libfontconfig.so (libc6) => /usr/X11R6/lib/libfontconfig.so libfontconfig.so (libc6) => /usr/lib/libfontconfig.so
spin:/home/johan# ldconfig -p | grep gimp libgimpwidgets-2.0.so.0 (libc6) => /usr/lib/libgimpwidgets-2.0.so.0
libgimpwidgets-2.0.so (libc6) => /usr/lib/libgimpwidgets-2.0.so libgimpui-2.0.so.0 (libc6) => /usr/lib/libgimpui-2.0.so.0 libgimpui-2.0.so (libc6) => /usr/lib/libgimpui-2.0.so libgimpui-1.2.so.0 (libc6) => /usr/lib/libgimpui-1.2.so.0 libgimpthumb-2.0.so.0 (libc6) => /usr/lib/libgimpthumb-2.0.so.0 libgimpthumb-2.0.so (libc6) => /usr/lib/libgimpthumb-2.0.so libgimpprint.so.1 (libc6) => /usr/lib/libgimpprint.so.1 libgimpprint.so (libc6) => /usr/lib/libgimpprint.so libgimpmodule-2.0.so.0 (libc6) => /usr/lib/libgimpmodule-2.0.so.0
libgimpmodule-2.0.so (libc6) => /usr/lib/libgimpmodule-2.0.so libgimpmath-2.0.so.0 (libc6) => /usr/lib/libgimpmath-2.0.so.0 libgimpmath-2.0.so (libc6) => /usr/lib/libgimpmath-2.0.so libgimpcolor-2.0.so.0 (libc6) => /usr/lib/libgimpcolor-2.0.so.0 libgimpcolor-2.0.so (libc6) => /usr/lib/libgimpcolor-2.0.so libgimpbase-2.0.so.0 (libc6) => /usr/lib/libgimpbase-2.0.so.0 libgimpbase-2.0.so (libc6) => /usr/lib/libgimpbase-2.0.so libgimp-2.0.so.0 (libc6) => /usr/lib/libgimp-2.0.so.0 libgimp-2.0.so (libc6) => /usr/lib/libgimp-2.0.so libgimp-1.2.so.0 (libc6) => /usr/lib/libgimp-1.2.so.0
-Yosh
2004-04-12 19:40:08 UTC (almost 21 years ago)
fontconfig and gimp
johan writes:
The one in /usr/lib is part of the libfontconfig1 package and there should be none in /usr/X11R6/lib. If there's one, move it away.
