how to apply a stepping curve
13 of 13 messages available
how to apply a stepping curve Krzysztof Żelechowski 16 Mar 12:52
  how to apply a stepping curve Burnie West 16 Mar 22:44
  how to apply a stepping curve Chris Mohler 16 Mar 23:34
  how to apply a stepping curve Simon Budig 28 Mar 23:54
how to apply a stepping curve Krzysztof Żelechowski 17 Mar 07:59
how to apply a stepping curve Chris Mohler 17 Mar 16:10
how to apply a stepping curve Krzysztof Żelechowski 21 Mar 15:49
  how to apply a stepping curve rich 21 Mar 18:09
   how to apply a stepping curve Chris Mohler 21 Mar 18:45
    how to apply a stepping curve Rob Antonishen 21 Mar 19:04
     how to apply a stepping curve rich 21 Mar 20:11
     how to apply a stepping curve rich 21 Mar 20:12
   how to apply a stepping curve yahvuu 28 Mar 17:52
2011-03-16 12:52:44 UTC (almost 14 years ago)
When I create a curve to apply to an image, GIMP gives me only two choices: a freehand curve and a smooth curve. I need to apply a stepping curve (piecewise flat) and I am out of luck because there is no such option. Please help.
Originally posted at bugzilla:
Burnie West
2011-03-16 22:44:30 UTC (almost 14 years ago)
Not sure exactly what you want, but it is likely the pencil tool would help. It makes freehand curves or piecewise linear (using shift-click) curves.
Chris Mohler
2011-03-16 23:34:28 UTC (almost 14 years ago)
2011/3/16 Krzysztof Żelechowski :
There's a function in the PDB called gimp-curves-explicit:
"Modifies the intensity mapping for one channel in the specified drawable. The drawable must be either grayscale or RGB, and the channel can be either an intensity component, or the value. The 'curve' parameter is an array of bytes which explicitly defines how each pixel value in the drawable will be modified. Use the 'gimp-curves-spline' function to modify intensity levels with Catmull Rom splines."
So I guess it would theoretically be possible to write a script or plug-in for this.
Chris
2011-03-17 07:59:21 UTC (almost 14 years ago)
[Shift [Click]], same as [Click], only creates dents in the current colour curve. The resulting curve is piecewise linear, but there is no way to make it piecewise flat (except for drawing it freehand, which is impossible to accomplish reliably using a mouse.)
Chris
Chris Mohler
2011-03-17 16:10:26 UTC (almost 14 years ago)
On Thu, Mar 17, 2011 at 2:28 AM, Křištof Želechovski wrote:
Thank you.  This means it is unsupported (for the end user).  Could you be so kind and reopen my bug, or at least place a comment to that effect?
Can you provide an example of the type of curve you wish to apply?
I'm not sure what would be best - maybe a quick Inkscape drawing, a series of points or something else?
Chris
2011-03-21 15:49:28 UTC (almost 14 years ago)
Turn ccw:
Chris
rich
2011-03-21 18:09:36 UTC (almost 14 years ago)
Turn ccw:
Chris
I think you will have to fake it. Draw the curve and keep it as a path. Assuming you want (say) the x-axis to have equal increments, set up the grid, enable snap-to-grid, and paint constraining the line with shift for point-to-point and ctrl for angles, My attemp here http://imgur.com/8ElzN.
Chris Mohler
2011-03-21 18:45:12 UTC (almost 14 years ago)
We're talking about using straight line segments in the Curves tool (not the Bezier tool - we're not talking about paths).
I still haven't thought up an easy solution.
Chris
Rob Antonishen
2011-03-21 19:04:49 UTC (almost 14 years ago)
Chris
If you export the curve to a file you can ee the syntax used, then create your own files that can be loaded into the curve tool.
-Rob A>
rich
2011-03-21 20:11:37 UTC (almost 14 years ago)
Chris
-Rob A>
That was roughly what I was thinking as well, develop an algorithm that will write a 'block'.
Here is one that I did as an experiment 'by hand' (well by spreadsheet and csv)
http://www.imageno.com/j662vataf0vtpic.html
rich
2011-03-21 20:12:04 UTC (almost 14 years ago)
Chris
-Rob A>
yahvuu
2011-03-28 17:52:02 UTC (almost 14 years ago)
Hi all,
... here's how to use the path as specification for a curves-alike color mapping:
0. Install Rob Antonishen's "Sample Gradient along Path" Script [1]
1. Create image 256x256 pixels 2. Draw gradient black to white from bottom to top 3. Create the desired curve as a path 4. Create a new gradient via "sample gradient along path" - with 256 steps and
- sample radius = 1
5. Switch to target image
6. Apply Colors->Map->Gradient Map
not for the faint of heart...
regards, peter
[1] http://ffaat.pointclark.net/blog/archives/155-GIMP-Script-Sample-a-Gradient-along-a-Path.html
Simon Budig
2011-03-28 23:54:54 UTC (almost 14 years ago)
It should be reasonably easy to implement a new curve type that implements this kind of piecewise constant function. One starting point for this could be the function gimp_curve_calculate() in app/core/gimpcurve.c.
IMHO also interesting would be a piecewise linear type that connects the control points with straight lines.
Bye, Simon
