Help needed looking for a plug-in
Help needed looking for a plug-in Tom Williams 15 Mar 18:10
  Help needed looking for a plug-in Carol Spears 16 Mar 00:18
   Help needed looking for a plug-in Tom Williams 16 Mar 00:48
Tom Williams
2011-03-15 18:10:32 UTC (about 14 years ago)
Hi! Sometime last year, I used a Gimp 2.6 plugin which took an image and put vertical photo sprockets on the left and right sides of the image, with the text "1A" printed on it. This plugin was similar to the "filmstrip" plugin except the filmstrip plugin puts the photo sprockets on the top and bottom of the image, not on the left and right sides.
I've been looking for this plugin but I don't see it in my Gimp 2.6 installation anymore.
Any ideas on which plugin I'm trying to describe? Again, it functions similar to the "filmstrip" plugin but it applies to only ONE image and puts the sprockets (the holes in the black edges of the photo, like a full color negative) on the left and right sides of the image.
Thanks!
Peace...
Tom
Carol Spears
2011-03-16 00:18:08 UTC (about 14 years ago)
/Filters/Decor/Slide...
http://www.gimpedimenta.org/resources/fu/script-fu-slide-System-alphabetical.shtml
I think this is what and where you are looking for.
Tom Williams
2011-03-16 00:48:13 UTC (about 14 years ago)
Yep, that's it! THANK YOU!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! :)
Peace...
Tom
