Edit text problem?
Edit text problem? Alex 09 Feb 13:45
  Edit text problem? Joe Carsto 10 Feb 17:46
Edit text problem? . 09 Feb 13:56
  Edit text problem? Nishandh M 09 Feb 21:01
Alex
2011-02-09 13:45:51 UTC (almost 14 years ago)
Edit text problem?
I made a banner with a transparent background and put text onto it. There's only 1 layer- the background. It was saved as a gif.
Is there a way to edit the text in it again because I can't edit it now?
2011-02-09 13:56:49 UTC (almost 14 years ago)
Edit text problem?
Thanks
On 02/09/2011 08:50 AM, Olivier Lecarme wrote:
Your image was not saved, which would have been saving to XCF. It was exported to GIF, which does not remember anything about layers, for example.
You cannot change your image back to a text layer, but you can still change it. It would probably be better to start again, and to save your image XCF, before exporting also to GIF.
Nishandh M
2011-02-09 21:01:00 UTC (almost 14 years ago)
Edit text problem?
:D pls attach the banner, so that I can suggest possible workflows. Check you documentary history in GIMP, may be some intermediate stage is left in temp.
On Wed, Feb 9, 2011 at 7:26 PM, . wrote:
Thanks
Joe Carsto
2011-02-10 17:46:36 UTC (almost 14 years ago)
Edit text problem?
You need to save your image in GIMP native format using .XCF extension in order to be able to edit your text at a later time.
