reverting to base state
13 of 13 messages available
reverting to base state Jeremy Nell 04 Feb 14:41
  reverting to base state rich 04 Feb 16:53
  reverting to base state Owen 04 Feb 21:39
   reverting to base state Jeremy Nell 04 Feb 21:42
reverting to base state Jernej Simončič 04 Feb 14:47
  reverting to base state Jeremy Nell 04 Feb 14:52
reverting to base state Kevin Brubeck Unhammer 04 Feb 15:26
  reverting to base state Jeremy Nell 04 Feb 15:30
   reverting to base state phanisvara das 04 Feb 15:41
    reverting to base state Jeremy Nell 04 Feb 15:51
     reverting to base state Michael Schumacher 04 Feb 16:14
    reverting to base state Rob Antonishen 04 Feb 16:15
reverting to base state Kevin Brubeck Unhammer 04 Feb 16:12
Jeremy Nell
2011-02-04 14:41:44 UTC (over 14 years ago)
1. I create an artwork and save it as a Gimp file. 2. I later open it and make changes to it, saving along the way. 3. I then realise that I want to revert to the original state when I opened it.
4. Gimp seems to evert only to the last saved state, rather than the state when I opened it.
Is there a way to revert to the original instance?
Jernej Simončič
2011-02-04 14:47:54 UTC (over 14 years ago)
If you didn't do more edits than the undo system can handle, you can use that, but otherwise no. Revert just means "discard everything since last save".
Jeremy Nell
2011-02-04 14:52:56 UTC (over 14 years ago)
That's unfortunate. Sometimes, it is handy to be able to revert to the newly opened file state.
*Comparison alert*
In Photoshop, this option is literally one click; it's in the history toolbar as the last (or first) action (regardless of the number of undo states).
This really should be a standard feature.
2011-02-04 15:26:53 UTC (over 14 years ago)
Jeremy Nell writes:
So basically, keep the initially opened file as a "special" persistent undo state, regardless of saves happening in between?
(Emacs does this using backup files... although I guess the user would not want to see lots of HUGEIMAGE.xcf~ files scattered in their directories.)
Hmm, taking that idea further, how about being able to tick off an undo state, and say "don't delete this state no matter how many further actions I do"?
Apropos, http://registry.gimp.net/node/14246 seems like a nice script, although it does not solve this exact problem.
Jeremy Nell
2011-02-04 15:30:00 UTC (over 14 years ago)
Now we're talking.
How possible is it for someone to create a script / plugin that solves this problem? (Sadly, I know nothing about coding.)
On 04/02/2011 17:26, Kevin Brubeck Unhammer wrote:
Jeremy Nell writes:
phanisvara das
2011-02-04 15:41:48 UTC (over 14 years ago)
to me the easiest seems to make it a habit to "save as" any image you want to be able to revert to. no scripting required...
Jeremy Nell
2011-02-04 15:51:15 UTC (over 14 years ago)
Fair enough, but that's laborious. Why not simply have a history state that, with one click, reverts everything to how it was when you opened it?
2011-02-04 16:12:00 UTC (over 14 years ago)
"phanisvara das" writes:
As a programmer, I find it irking to do the same, repetitive action more than three or four times, when I know that the machine in front of me would uncomplainingly do it a million times if only I gave it the right instructions... but yeah, there is the cost/effect to take into account.
2011-02-04 16:14:58 UTC (over 14 years ago)
Von: Jeremy Nell
See https://bugzilla.gnome.org/show_bug.cgi?id=148930
In general, someone just has to implement something like this (see https://bugzilla.gnome.org/show_bug.cgi?id=51937 for a discussion of macro recording, saving the undo history may be closely related).
Approaches via autosaving should take https://bugzilla.gnome.org/show_bug.cgi?id=138373 into consideration, this report summarizes some of the challenges to be handled.
Regards, Michael
Rob Antonishen
2011-02-04 16:15:17 UTC (over 14 years ago)
Here's a little script I wrote:
http://registry.gimp.org/node/14246
to do the save-as to a unique file.
I just added a key-binding to call it.
-Rob A>
rich
2011-02-04 16:53:04 UTC (over 14 years ago)
There is a gimp plugin 'iterative save' http://registry.gimp.org/node/18873
but you have to invoke the save. still it can be useful.
for once the linux plugin is easy to compile gimptool-2.0 --install .c
Owen
2011-02-04 21:39:34 UTC (over 14 years ago)
File->Revert
Jeremy Nell
2011-02-04 21:42:47 UTC (over 14 years ago)
That reverts to the last saved instance; not the original instance.
File->Revert
