Help needed stroking an eliptical selection
Help needed stroking an eliptical selection Tom Williams 03 Apr 20:42
  Help needed stroking an eliptical selection Sven Neumann 03 Apr 21:11
   Help needed stroking an eliptical selection Simon Budig 03 Apr 21:40
    Help needed stroking an eliptical selection Tom Williams 03 Apr 22:40
Tom Williams
2004-04-03 20:42:17 UTC (about 21 years ago)
Hi! I'm trying to make an elliptical border around part of an image, sort of like a picture frame. I use the "Select Elliptical Regions" tool to select my region. Then I choose the color I want for the selection and I choose a 5x5 solid circle brush to use for the stroke of the selection. Then I right-click on the image and click "Edit... Stroke Selection" and my "frame" appears around the image. Cool.
I noticed there are some jagged edges along parts of the "frame" and I would like to know if there's a way they can be eliminated.
Here is a screenshot illustrating what I've got thus far:
http://www.pixhost.com/pixt/tomdkat/stroke.jpg
The top and bottom of the frame look great but the sides have the jagged edges. Is there any way I can eliminate the jagged edges?
Once I have the frame, my plan is to add a bevel to it to give it more of a "real" frame look. :) Here is a sample of the above image with a 5-thickness setting Script-Fu bevel:
http://www.pixhost.com/pixt/tomdkat/stroke-bevel.jpg*
*I've found the higher the bevel thickness, the more pronounced the jagged edges are. :(
I'm using Gimp 2.0 on Linux.
Thanks in advance!
Peace...
Tom
2004-04-03 21:11:47 UTC (about 21 years ago)
Tom Williams writes:
Don't use the paintbrush to stroke the selection, but use the Stroke options in the upper part of the Stroke dialog.
Simon Budig
2004-04-03 21:40:06 UTC (about 21 years ago)
Well, unfortunately this doesn't help much. The better way to fix this is to convert the selection boundary to a path and stroke the path.
I tried hacking the boundary stroking to get a better stroking, but my experiments turned out to lead to unexpected results. A discussion of this is in bug #50730.
Bye,
Simon
Tom Williams
2004-04-03 22:40:36 UTC (about 21 years ago)
Bye,
Simon
Thanks for the tip! Converting the selection to a path seems be working much better for me! :)
Peace...
Tom
