Problem with plug-in-sample-colorize in batch mode
Problem with plug-in-sample-colorize in batch mode Maarten De Munck 24 Jan 20:40
  Problem with plug-in-sample-colorize in batch mode saulgoode@flashingtwelve.brickfilms.com 25 Jan 15:49
  Problem with plug-in-sample-colorize in batch mode saulgoode@flashingtwelve.brickfilms.com 27 Jan 14:52
   Problem with plug-in-sample-colorize in batch mode Maarten De Munck 27 Jan 19:52
Maarten De Munck
2011-01-24 20:40:52 UTC (almost 15 years ago)
I want to sample colorize a lot (a few hundred) of black-and-white images (scanned from negative and retouched and so on). I would like to avoid doing it manually, so I searched and I discovered the batch mode of the Gimp. I had a Scheme class about 15 years ago, and it looks like I still remembered something.
With some help of some examples found on the net and the Gimp help, I wrote the script:
(define (maarten-tiff-jpeg pattern                            samplefilename)   (let* ((filelist (cadr (file-glob pattern 1)))          (sampleimage (car (gimp-file-load RUN-NONINTERACTIVE samplefilename samplefilename)))
         (sampledrawable (car (gimp-image-get-active-layer sampleimage))))     (while (not (null? filelist))
           (let* ((filename (car filelist))                   (image (car (gimp-file-load RUN-NONINTERACTIVE filename filename)))
                  (drawable)
                  (fileparts)
                  (filenamejpeg))
             (set! drawable (car (gimp-image-get-active-layer image)))              (plug-in-sample-colorize RUN-NONINTERACTIVE image drawable sampledrawable TRUE TRUE FALSE TRUE 0 255 1.0 0 255)              (set! fileparts (strbreakup filename "."))              (set! fileparts (butlast fileparts))              (set! filenamejpeg (string-append (unbreakupstr fileparts ".") ".jpg"))
             (gimp-file-save RUN-NONINTERACTIVE image drawable filenamejpeg filenamejpeg)
             (gimp-image-delete image))            (set! filelist (cdr filelist)))     (gimp-image-delete sampleimage)))
And it seems to work fine, except for the plug-in-sample-colorize call. So it reads the tiff file and writes a jpeg file. I also tried to explicitly convert the grayscale image to rgb before the plug-in-sample-colorize call, but it doesn't really help (well, the resulting jpeg file is a black and white rgb image in that case, so the command is actually executed, but it is still not sample-colorized).
Anybody any idea what I'm doing wrong?
Maarten
Gimp-user mailing list
2011-01-25 15:49:31 UTC (almost 15 years ago)
The problem seems to lie with Sample Colorize plug-in. From looking at the source code, it appears to not actually do anything if invoked noninteractively. I will investigate further and report back.
Quoting Maarten De Munck :
                  (drawable)
                  (fileparts)
                  (filenamejpeg))
Maarten _______________________________________________ Gimp-user mailing list
2011-01-27 14:52:56 UTC (over 14 years ago)
If you apply the patch attached to the following bug report and recompile the plug-in, your script should then work.
https://bugzilla.gnome.org/show_bug.cgi?id=640612
Maarten De Munck
2011-01-27 19:52:03 UTC (over 14 years ago)
It works perfectly! Thank you for your help!
Best regards,
Maarten
2011/1/27 :
