specify png background color?
        On Saturday 03 April 2004 09:32, Steve Stavropoulos wrote:
On Sat, 3 Apr 2004, Jeffrey Brent McBeth wrote:
On Sat, Apr 03, 2004 at 12:32:25AM -0800, Tom Williams wrote:
Zhang Weiwu wrote:
Hello. I have a png logo with alpha channel, it looks good on
every browser excepte IE, which rander the alpha channel to a
single color.
I wish to set the optional png background color to be #222,
the background color of the webpage where the logo is. In
this case even IE failed to rander alpha channel the picture
is still displayed with a not-very-ugly background.
But how? Is it possible? (I am using GIMP pre-2.0)
Erm, last I checked, you have your background color (in the color
chooser) be what you want the PNGs background color to be, then
when you save the PNG, you make sure "Save Background Color" is
turned on.
You don't have to turn on "Save Background Color", in fact I think
it is best to turn it off. Either way, IE will show as background
what your background color (in the color chooser) was when you
saved your image.
At least one difference the "save the background color"  toggle does,
is, when you uncheck "save colors from transparent pixels", all
transparent pixels are reset to the background color if it is ON or
to Black, if it is off.
I am posting it on this thread because it is an information that would
be hard to find out by trial and error, and it is part of one of my
few (rather few) code contribs. to the GIMP.
