Jam Studio Pressure Sensitivity
On Sunday, January 23, 2011, Yart wrote:
Hi.
I got a cheap old tablet from my brother recently (Jam Studio KG-TAB1
tablet, company went out of business) and I've installed it and
everything. Works fine. Pressure sensitivity works perfectly in
Photoshop, but I can't get the pressure sensitivity to work in The Gimp.
I'm running Windows XP, and my current install of The Gimp is 2.6.10.
Is there a simple step I'm forgetting to do?
I'm not familiar with that model but as a start
first
Does the tablet behave as a mouse in gimp? (ie draws but no pressure)
second
Have you checked the settings in Gimps
Edit -> Preferences -> Input Devices -> Configure Extended Input Devices?
the dropdown in this config window should show your device. If it does then
you can modify the devices parameters there.
That's about all the help I can give you, I don't use windows and have no
idea if Gimp has any requirements not provived by that device.
Good luck,
see ya
dh
