Scaling / rotating images and focus
| Scaling / rotating images and focus | Jeremy Nell | 21 Jan 10:16 |
| Scaling / rotating images and focus | Mikel Garai | 21 Jan 10:20 |
| Scaling / rotating images and focus | Jeremy Nell | 21 Jan 10:33 |
| Scaling / rotating images and focus | Jeremy Nell | 26 Jan 08:22 |
| Scaling / rotating images and focus | peter kostov | 26 Jan 09:28 |
| Scaling / rotating images and focus | Jeremy Nell | 26 Jan 10:02 |
| Scaling / rotating images and focus | Ofnuts | 26 Jan 10:06 |
| Scaling / rotating images and focus | Jeremy Nell | 26 Jan 10:14 |
| Scaling / rotating images and focus | " | 26 Jan 13:15 |
| Scaling / rotating images and focus | Jeremy Nell | 28 Jan 08:58 |
| Scaling / rotating images and focus | Tőkés Ábel | 28 Jan 09:09 |
| Scaling / rotating images and focus | Jeremy Nell | 28 Jan 09:16 |
| Scaling / rotating images and focus | Rob Antonishen | 28 Jan 13:46 |
1. I have an illustration with a few layers (lines and colours). 2. I drag and drop, let's say, an image of a TV onto the illustration. 3. I move the TV's layer down to below all the layers, so that it's at the bottom and appears partly behind, say, a cabinet. 4. I want to scale and rotate it so that it looks better (still behind the cabinet). I click the Rotate tool. 5. When I rotate the TV, it no longer appears behind all the other layers (and, thus, behind the cabinet). It appears as if it were the top most layer and, thus, in front of the cabinet.
Is there a way to make it NOT do that? This is because I physically can't see behind it, so my rotating becomes guesswork; if my rotation is wrong, then I undo and try again, which becomes a bit tedious.
The rotate tool have an "opacity" slider for the preview in the "tool options dialog".
Is there a way to make it NOT do that? This is because I physically can't see behind it, so my rotating becomes guesswork; if my rotation is wrong, then I undo and try again, which becomes a bit tedious. _______________________________________________ Gimp-user mailing list
Thanks. That does help, but not completely, because the more you lessen the opacity, the less of the preview you can see. It still appears on top of all the layers, rather than in the layer where it was originally positioned (in this case, at the bottom).
https://lists.XCF.Berkeley.EDU/mailman/listinfo/gimp-user_______________________________________________ Gimp-user mailing list
The more I work in Gimp, the more I realise that this is something that needs to be looked at by the developers, as it is not very intuitive.
Again, I've found how the focus of the image being rotated / scaled interferes with the rest of the working area. For example, if I set a particular layer's opacity to 20% and the layer is at the bottom of all other layers, why, then, does the opacity become 100% and the layer suddenly appear on top of all other layers?
This makes it very difficult to work efficiently.
Is there a way to fix this / work around it?
I don't have a solution, but would like to second this - it is really counter productive. The layer should indeed stay where it is and do not change settings like opacity, etc.
Peter
Gimp-user mailing list Gimp-user@lists.XCF.Berkeley.EDU https://lists.XCF.Berkeley.EDU/mailman/listinfo/gimp-user
Rotating and scaling a layer should not affect the opacity and layer positioning, logically.
Peter
The Scale and Rotate tools have an opacity slider for the preview...
Except that the opacity slider makes it tougher to see the preview as the opacity is made less.
But that's besides the point.
1. If I've set the opacity of the layer, then the opacity of that layer should remain as is when I scale / rotate. 2. When I scale / rotate, the layer's position in the stack should remain in its place, rather than suddenly appear at the top of every layer when being rotated / scaled.
Surely, this is a reasonable request?
It indeed is, and this should eventually solve itself as GEGL is more properly integrated with the layer stack of GIMP and what is shown is no longer a preview but the actual result. For now the preview is a hack that provides better visual feedback than just a bounding box or a wireframe grid.
/Øyvind K.
«The future is already here. It's just not very evenly distributed» -- William Gibson http://pippin.gimp.org/ http://ffii.org/ _______________________________________________ Gimp-user mailing list Gimp-user@lists.XCF.Berkeley.EDU https://lists.XCF.Berkeley.EDU/mailman/listinfo/gimp-user
How does one go about requesting this as a feature enhancement?
To include this in Gimp would vastly improve usability in this regard, as well as making logical (and practical) sense.
Øyvind have already answered your question:
"It indeed is, and this should eventually solve itself as GEGL is more properly integrated with the layer stack of GIMP and what is shown is no longer a preview but the actual result. For now the preview is a hack that provides better visual feedback than just a bounding box or a wireframe grid.
/Øyvind K."
This means that your request will be automatically solved in the future release. You don't have much chance that anyone will spend his/her time by writing a temporary solution.
Abel
I must have missed that response.
Thanks. Looking forward to the new release!
/Øyvind K."
Abel
Not sure about GEGL previews, bu there is a new transform tool spec:
http://gui.gimp.org/index.php/Transformation_tool_specification
To combine scale, shear and rotate into one tool. No mention of how previews are to be handled, however.
-Rob A>
/Øyvind K."
You don't have much chance that anyone will spend his/her time by writing a temporary solution.Abel
