Scaling images
Scaling images Jeremy Nell 17 Jan 09:31
  Scaling images Ofnuts 17 Jan 10:08
Jeremy Nell
2011-01-17 09:31:02 UTC (over 14 years ago)
Scaling images
I am new to Gimp (converted from Photoshop because I migrated to Ubuntu). Gimp is great and I'm enjoying its speed and power. But I am struggling with a few things, some of which I'll mail to this list and hopefully get some feedback.
When scaling an image, Gimp keeps the original image underneath the one being scaled. I guess this is so that I can visually compare the difference in size before applying.
However, this becomes less intuitive when you're dealing with, say, a detailed drawing. When scaling, lines appear everywhere and it becomes messy. I don't seem to have an option to hide the full-size image underneath; the closest is to give it a grid or outline, neither of which are helpful in this scenario. Even making the underneath image 50% of its opacity would be more helpful.
Or am I doing something wrong?
2011-01-17 10:08:39 UTC (over 14 years ago)
Scaling images
More like the latter I think... From what you describe, you are using the Scale tool, that is really meant to adjust layers over each other (and this will produce a smaller layer without reducing the global image size).
If you want to scale the whole image. you should use the aptly located and named Image/Scale image :-)
Advice: in Edit/Preferences/Tools make sure that your scaling method is the right one: normally the best one is Sinc, but since it takes some CPU (though it's really OK with most images on recent PCs), the default method is a somewhat less CPU-intensive one.
