Gimp not Recognizing Tablet
Gimp not Recognizing Tablet sacrificed4happy@aol.com 02 Jan 07:11
  Gimp not Recognizing Tablet Ofnuts 02 Jan 09:55
  Gimp not Recognizing Tablet Ofnuts 07 Jan 18:26
   Gimp not Recognizing Tablet SOLVED? David Herman 09 Jan 00:13
    Gimp not Recognizing Tablet SOLVED? Ofnuts 09 Jan 01:16
     Gimp not Recognizing Tablet SOLVED? Jennifer 09 Jan 02:02
2011-01-02 07:11:42 UTC (over 14 years ago)
I tried to "install" my wacom tablet into the Gimp program, but nothing happened. In Gimp,
I went under Preferences, went to "Input Devices" and clicked on "Configure Extended Input Devices". A pop-up came up and said "No Extended Input Devices". I checked the current "Input Controllers" to see if the tablet was already listed there, but it wasn't.
I really need some help with this please. Thanks!
2011-01-02 09:55:57 UTC (over 14 years ago)
If you are using Windows, run at least once the utilities provided with the tablet. One of them creates a tablet properties file and it seems Gimp uses that to determine if a tablet is available. Sorry I can't be more specific, I'm now running Linux.
2011-01-07 18:26:05 UTC (over 14 years ago)
From a W7 user in GimpForum:
I added DirectX DirectInput [in devicerc] as active controller in the input controllers section of input devices. After a restart Gimp was able to recognize my Wacom-device.
David Herman
2011-01-09 00:13:39 UTC (over 14 years ago)
-----------snip--------
Solution:
Hi Ofnuts,
I was just going through my mail and trying to figure out if I could offer some assistance. Only after re-reading a few of the mails on the list did I realize you had solved your issue...
I added solved to the subject line so that if another user searches the archives with this problem they will find your solution more easily.
If I am incorrect and you are still having problems try posting a bit more information
see ya
dh
2011-01-09 01:16:08 UTC (over 14 years ago)
Solution:
Hi Ofnuts,
see ya
dh
I'm not the one with the problem... the post you refer to is just quoting a post to GimpForums by someone with a similar problem, in case it helps the OP.
Ofnuts, guilty of turning [Gimp-user] into [Aspirin-user]
Jennifer
2011-01-09 02:02:47 UTC (over 14 years ago)
This didn't end up solving the problem at all. But it kind of work itself out but now I have another problem. :/
Now I can't use any other colours except black and white. :/ I cant use any other colours with my pen but I can with my mouse.
Solution:
Hi Ofnuts,
see ya
dh
