gradient based on manual (lasso) selection
gradient based on manual (lasso) selection Eric P 26 Dec 18:55
  gradient based on manual (lasso) selection Ofnuts 26 Dec 19:30
Eric P
2010-12-26 18:55:50 UTC (almost 15 years ago)
GIMPers,
Is there a way to create a gradient (black->white) based off a closed lasso selection? So the resulting gradient would start black along the edge of the selection and expand out to white in all directions away from the selection.
My end goal is to create a quick mask that I can blur to create a background with an exaggerated out of focus look.
Thanks for reading (hope that all made sense)! Eric
2010-12-26 19:30:21 UTC (almost 15 years ago)
On 12/26/2010 07:55 PM, Eric P wrote:
GIMPers,
That's one of the uses of the WrapMap filter I wrote:
http://registry.gimp.org/node/24754 http://sourceforge.net/projects/gimp-wrapmap/
Added bonus: you can run WrapMap to create the wrapped gradient in the layer mask. And if you use the "curves" dialog/tool on the mask you can change the linear gradient to something else and thus control finely how the blur appears.
