Gimp-2.7 Color From Gradient
Gimp-2.7 Color From Gradient iceburg 13 Dec 17:02
  Gimp-2.7 Color From Gradient Owen 14 Dec 05:53
  Gimp-2.7 Color From Gradient Alexandre Prokoudine 14 Dec 14:45
   Gimp-2.7 Color From Gradient iceburg 14 Dec 22:53
2010-12-13 17:02:26 UTC (over 14 years ago)
I've built Gimp-2.7 from git source on Linux (Debian) and also used the pre-compiled windows version and in either one, the color from gradient option only uses the current foreground color. Does it work correctly for anyone else? I know it's a development version and all that but I just wanted to see if it's just me. If it is broken, does that need to be entered into the bug system or should we just wait and see if it starts working again at some point?
Owen
2010-12-14 05:53:05 UTC (over 14 years ago)
Well I just tried it, build of a couple of days ago and all these options work;
FG to BG (hardedge) FG to BG (HSV Clockwise)
FG to BG (HSV Counter clockwise)
FG to BG (RGB)
The HSV ones start off and finish with the set color, just not sure what to expect in the middle.
Ubuntu-9.04 with gimp and most dependencies built in a separate folder.
Owen
2010-12-14 14:45:57 UTC (over 14 years ago)
This is because now you have to check any box for Color in the new painting dynamics palette.
2010-12-14 22:53:57 UTC (over 14 years ago)
Thanks for the update, I guess I should've poked around a little more.
