Gimp won't open
Gimp won't open Phillip Hatfield 11 Dec 03:30
  Gimp won't open Ofnuts 11 Dec 09:17
   Gimp won't open Mike Williams 11 Dec 09:42
  Gimp won't open yethu 02 Apr 19:02
  Gimp won't open yethu 02 Apr 19:08
Phillip Hatfield
2010-12-11 03:30:35 UTC (over 14 years ago)
Gimp won't open
Computer: MacBook Pro
OS: Mac OS X 10.6.5 Snow Leopard
Processor: 2.26 GHz Intel Core 2 Duo Memory: 2 GB 1067 MHz DDR3
Gimp will not open. I tried reinstalling it, but that didn't help. I tried reinstalling X11/XQuartz, logging out of my account, restarting my computer, but it still won't open.
-------------- next part -------------- An HTML attachment was scrubbed...
URL: /lists/gimp-user/attachments/20101210/36b62372/attachment.html
2010-12-11 09:17:48 UTC (over 14 years ago)
Gimp won't open
If the concept applies to OSX: start from a command prompt with a --verbose parameter, you may find what it is doing when it hangs. And check your plugins directory in your personal profile (or even more radically, get rid of your personal profile after backing up anything of interest: brushes, gradients, etc... -------------- next part -------------- An HTML attachment was scrubbed...
URL: /lists/gimp-user/attachments/20101211/28e26b01/attachment.html
Mike Williams
2010-12-11 09:42:02 UTC (over 14 years ago)
Gimp won't open
Computer: MacBook Pro OS: Mac OS X 10.6.5 Snow Leopard
Hi there. I was going to suggest something similar to what ofnuts said, but wasn't sure if it would work on a Mac. I have access to a mac with OS X 10.5.8 with gimp 2.6.11 and did some poking around.
What happens if you start X11 by itself first? ( in finder you can click on /Applications/Utilities/X11.app)
If that works then open a terminal window and type:
/Applications/Gimp.app/Contents/MacOS/Gimp --verbose
Then copy what is on the terminal window and post it in a reply.
If X will not start I have some other ideas. Let us know what happens when you try these suggestions.
Cheers,
Mike -------------- next part -------------- An HTML attachment was scrubbed...
URL: /lists/gimp-user/attachments/20101211/d0bab4b4/attachment.html
2011-04-02 19:02:22 UTC (over 14 years ago)
Gimp won't open
2011-04-02 19:08:43 UTC (over 14 years ago)
Gimp won't open
After downloading, instead of clicking the icon (the animal head), drag it into Applications (on Finder). Then click it to install and open the program.
(Perhaps someone could add a note saying that to show when the icon is first clicked....)
