GIMP ignores my screen resolution settings
GIMP ignores my screen resolution settings Johnny Rosenberg 04 Dec 19:31
  GIMP ignores my screen resolution settings Ofnuts 04 Dec 20:19
  GIMP ignores my screen resolution settings drc at shadowdrama.net (Ville P 04 Dec 21:31
Johnny Rosenberg
2010-12-04 19:31:01 UTC (over 14 years ago)
Edit ? Preferences ? View ? Screen resolution ? Calibrate? ? I measured on the screen and got 424 mm horisontally and 185,5 mm vertically. The result was a resolution of 95.849?95.849 dpi. Restarted GIMP, created a new image of 100?100 mm, viewed it at 100% zoom but it was still 75?75 mm, just like before I calibrated. Does the screen resolution thing work at all? I experimented with other settings too, but still a 100?100 mm image was 75?75 mm, no matter what values I used.
The quick workaround for my screen is to view at 133% zoom, but that doesn't feel right?
Tested this at 2 different computers with the same lack of results: Ubuntu 9.10, GIMP 2.6.8
Ubuntu 10.10, GIMP 2.6.10
Am I supposed to restart Ubuntu for these settings to take place?
2010-12-04 20:19:52 UTC (over 14 years ago)
You are looking at the wrong place; the screen resolution is one thing, but the DPI used to compute thje size of an image in pixels when you give a dimension in inches is part of the "Advanced options" in the "new image" dialog. Its default can be set in teh general preferences in the "default new image" section.
2010-12-04 21:31:57 UTC (over 14 years ago)
Disable "Dot for Dot". It is the second item in the view-menu.
