Fwd: Questions About Creating Panoramas From Several Images
Fwd: Questions About Creating Panoramas From Several Images Mark Phillips 30 Nov 01:25
Mark Phillips
2010-11-30 01:25:22 UTC (over 14 years ago)
Ooops...didn't hit reply to all.
---------- Forwarded message ---------- From: Mark Phillips
Date: Mon, Nov 29, 2010 at 6:24 PM
Subject: Re: [Gimp-user] Questions About Creating Panoramas From Several Images
To: Alexandre Prokoudine
On Mon, Nov 29, 2010 at 5:59 PM, Alexandre Prokoudine < alexandre.prokoudine@gmail.com> wrote:
On 11/30/10, Mark Phillips wrote:
P.S. I have also tried Hugin, which I could not get to work,
What exactly didn't work?
I had a lot of trouble creating the points. I installed Hugin from the Debian respositories (v 2010.0.0.5045) and out of the box I got the error message about the non-free point calculating module. I then installed another debian package - the new all free c version, and that did not work. I kept getting error 250. So then I tried running panorama-c-sift and panorama-c-complete from the command line and got lots of output and no errors. I then imported the resulting projects into Hugin and clicked on create panorama in the assistant and I got an image that was all distorted and bore little resemblance to my original images. I tried to put the pictures together manually, and I couldn't get the 'quick panorama' button to generate a useable image. Very frustrating. I laughed when I found this article -
https://panospace.wordpress.com/2010/09/26/the-quest-is-over/......I guess I will have to wait until next year for cpfind to try it again.
If you can point me to a step by step tutorial that would be great!
Mark
http://libregraphicsworld.org
