gmic and Gimp 2.6
gmic and Gimp 2.6 Toonman 14 Nov 13:33
  gmic and Gimp 2.6 Ofnuts 14 Nov 14:02
   gmic and Gimp 2.6 Burnie West 14 Nov 21:32
    gmic and Gimp 2.6 photocomix 16 Nov 13:56
   gmic and Gimp 2.6 Toonman 28 Nov 12:14
  gmic and Gimp 2.6 ursaminor 11 Dec 17:21
2010-11-14 13:33:11 UTC (over 14 years ago)
gmic and Gimp 2.6
Hi I'm using Ubuntu 10.10 and I'm trying to install the gmic plugin. Every time I try to drop the plugin into the plugin folder Ubuntu refuses to let me do it. I get a notice saying I do not have permission. Any Ideas?
2010-11-14 14:02:39 UTC (over 14 years ago)
gmic and Gimp 2.6
There are two plugin folders: your own: ~/.gimp-2.6/plug-ins and the common one: /usr/lib/gimp/2.0/plug-ins/. Adding stuff in the common one requires root access (or sudo), but you should be able to drop the plug-ins in your own.
Burnie West
2010-11-14 21:32:35 UTC (over 14 years ago)
gmic and Gimp 2.6
If you happen not to have ~/.gimp-2.6/plug-ins you can create it.
2010-11-16 13:56:22 UTC (over 14 years ago)
gmic and Gimp 2.6
It seems impossible not to have ~/.gimp-2.6/,even if was deleted the folder would be created again just by loading gimp
What is very possible is the need to click in search "show hidden files" because the .gimp folder as everything with name starting with "." is as default is not visible
2010-11-28 12:14:41 UTC (over 14 years ago)
gmic and Gimp 2.6
Thanks
2010-12-11 17:21:00 UTC (over 14 years ago)
gmic and Gimp 2.6
Use System>Administration>Synaptic Package Manager. Insert "gmic" in Quick Search and install.
