text processing script
text processing script Damien 13 Nov 10:12
  text processing script Ofnuts 13 Nov 14:10
Damien
2010-11-13 10:12:55 UTC (about 15 years ago)
Hello the list !
I am totally new to the Gimp and would need to write a script that does the following:
1) generate text strings (with a specified font) using all consonants (except for "X", "W", "Y" and "Z") that look like this: - BXXXX
-XBXXX
-XXBXX
-XXXBX
-XXXXB
I was wondering if doing this through the Gimp is really efficient (I was thinking of using a spreadsheet instead).
2) Insert the above made lines in one jpeg picture each (800x600), vertically and horizontally centred.
3) Make five copies of every jpeg and manipulate contrast in order to fade from highest to lowest according to a certain step (luminance/square-root of 2).
To those wondering, this is for stimuli building in a psychology experiment.
I would very much appreciate any hints on which tools to use.
Cheers, Damien.
2010-11-13 14:10:38 UTC (about 15 years ago)
On 11/13/2010 11:12 AM, Damien wrote:
Hello the list !
There are two ways to script Gimp: Scheme (a LISP derivative) that is built-in, and Python that may be part of your install (and can be otherwise added later, even if it's not painless). I use Python.
-XBXXX
-XXBXX
-XXXBX
-XXXXB
This would be done by the script, likely light-years more efficient than a spreadsheet.
I suggest using PNG format for this instead. The files won't be bigger and you won't get any artifacts
For some definition of "contrast" :)
Gimp may be usable, but the ImageMagick toolbox with a shell script is likely to be a much better solution. See here for some examples wit text, while extenive image
manipulation is shown here:
(notet that you can even describe mathematically what you want...)
Cheers,
Damien.
