The version of my woodrat script I refrred to below works on
Mac GIMP version 2.6.7
Ubuntu GIMP version 2.6.8
Win GIMP version 2.6 10
Haven't tried 2.6.11 yet.
------- Forwarded message follows -------
To: gimp-user@lists.XCF.Berkeley.EDU
Subject: Re: [Gimp-user] script-fu: underscore?; script-fu-
register; script-fu-menu-register
Send reply to: gimp-user@alancampbelllists.ukfsn.org
Date sent: Mon, 04 Oct 2010 21:06:43 0
On 4 Oct 2010 at 10:21:16 PDT
saulgoode at flashingtwelve.brickfilms.com wrote:
It is not a problem with the branch register command not being
processed, but that branch registration seems to require that
plug-in be associated with it (see
'plugin_menu_branch_register_invoker()' in
app/pdb/plug-in-cmds.c). Apparently, when processed at the top
level of a Script-fu, there is no "current-active-plugin"; and
this leads to 'gimp_marshal_VOID__STRING_STRING_STRING' failing
because it is missing one of its parameters (the plug-in name).
Don't have source code, so I'll pass on the c. But I get the idea.
I did this:
(define (wrf_register_menu_branch)
(gimp-plugin-menu-branch-register
"/File/Create/W_oodrat")
"_Finger..."
(script-fu-register "wrf_create_template_finger"
(wrf_register_menu_branch) ; menu label
which works. (script-fu-register when it runs has to call
(wrf_register_menu_branch), which does the register thing.
A clever solution. However, I was unable to make it work with GIMP
2.6.10+. What version of GIMP are you using?
2.6.10 win32 on XP.
Anyway, my kludge seems to work.
Thanks for pointer on how to do it.
I'm not sure how robust your kludge is. If it is not version
specific then it may be working for you (and not me) because of
something other going on than just the code you posted here
(multiple procedure registrations in the same file perhaps). Could
you provide a complete listing of your script?
2000 lines overall, 1200 lines of code. Perhaps a bit excessive to
paste into a posting here. So for moment it's in woodrat.zip at
https://docs.google.com/leaf?id=0B6M_pjcD-
RRwNTZjODc0NzQtYjliMy00ZDBlLTgzZWItNDAyNDExMTA2YzU3&hl=en&authkey=CMGn
5i4
or
http://bit.ly/btzFxD
or
http://www.freedrive.com/folder/282054
In version posted I invoke (wr_register_menu_branch) 3 times, with
argument (the value to return each time). It also worked for me when
I just invoked it once (on the first (script-fu-register)).
Any comments or crits on code very welcome, e.g. if you happen to
notice me doing anything wildly inefficient. To actually run the
script you need the pattern file included in the zip.
------- End of forwarded message -------Yrs,
Alan
Anything worth fighting for is worth
fighting dirty for.
