Still problems with compiling GIMP 2.0 on ML9.2
7 of 7 messages available
Still problems with compiling GIMP 2.0 Tom Cole 26 Mar 21:44
  Still problems with compiling GIMP 2.0 dj 26 Mar 21:52
   Still problems with compiling GIMP 2.0 on ML9.2 Kyle Hamar 27 Mar 01:08
    Still problems with compiling GIMP 2.0 on ML9.2 Owen 27 Mar 07:36
     Still problems with compiling GIMP 2.0 on ML9.2 Henrik Brix Andersen 27 Mar 11:42
    Still problems with compiling GIMP 2.0 on ML9.2 Owen 27 Mar 07:38
    Still problems with compiling GIMP 2.0 on ML9.2 raymond ostertag 29 Mar 21:20
Tom Cole
2004-03-26 21:44:57 UTC (about 21 years ago)
I'm still trying to install GIMP 2.0 on Mandrake 9.2.
Making no headway at all. Have made a summary of what I've been doing. If anyone could shed light on this I would be VERY grateful. I have been doing the below after reading the INSTALL documents that accompanies the GIMP2 source code download.
1) atk 1.2.4 configures, makes and installs okay. 2) pango 1.2.5 - configures, makes and installs okay. 3) glib 2.2.3 configures, makes and installs okay.
4)When ./configure is run for gtk+2.2.2 I get this error message at the end:
checking for glib-2.0 >= 2.1.4 atk >= 1.0.1 pango >= 1.0.1... Package atk was not found in the pkg-config search path. Perhaps you should add the directory containing `atk.pc' to the PKG_CONFIG_PATH environment variable No package 'atk' found
configure: error: Library requirements (glib-2.0 >= 2.1.4 atk >= 1.0.1 pango
= 1.0.1) not met; consider adjusting the PKG_CONFIG_PATH environment
variable if your libraries are in a nonstandard prefix so pkg-config can find them.
Of course GIMP 2.0 won't build without gtk. So what do I do?
Many thanks in advance
Tom
dj
2004-03-26 21:52:21 UTC (about 21 years ago)
Install the gtk2.2[whatever]-devel package. All should be well after that.
dj
them.
Tom
Kyle Hamar
2004-03-27 01:08:00 UTC (about 21 years ago)
dj
I too have been attempting this compile under ML9.2 without success. The first significant "not found" in config.log is:
configure:30573: WARNING: libexif not found! EXIF support will not be built into the JPEG plug-in. libexif is available from http://www.sourceforge.net/projects/libexif
Oddly enough when I attempt to install libexif, it is found:
[root@kylesbox khamar]# urpmi libexif medium "contrib" uses an invalid list file: mirror is probably not up-to-date, trying to use alternate method Everything already installed
The "invalid list file" message is a known bug that is usually just ignored.
So if everything is already installed why is libexif not found?
I have carefully installed everything listed as required at gimp.org but have not overcome the errors in configure. BTW, ./configure completes normall and does not "shell out" with excessive errors. Any attempt to "make" however results in failure.
Config.log has more errors as well. Here is the next one:
configure:30626: gcc -o conftest -g -O2 -Wall conftest.c -laa >&5 /usr/bin/ld: cannot find -laa
collect2: ld returned 1 exit status
configure:30632: $? = 1
configure: failed program was:
| /* confdefs.h. */
Kyle
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.2.3 (GNU/Linux)
iD8DBQFAZMXjmmpdxC1mkmkRAsXbAJ0fBy+/Mao0X5+tyz+1rPI4szpEwACeLufw Mi1mY0KIrwb7jKfEGXweul0=
=JpNE
-----END PGP SIGNATURE-----
Owen
2004-03-27 07:36:05 UTC (about 21 years ago)
do you have a /usr/lib/pkgconfig/libexif.pc or is it in /usr/local/lib/pkgconfig/libexif.pc
If the latter, the quick and dirty answer is to copy it to /usr/lib/pkgconfig/
Owen
2004-03-27 07:38:34 UTC (about 21 years ago)
| /* confdefs.h. */
If you havent already done so, as root, run 'ldconfig' and see what happens. (I could be totally wrong here)
2004-03-27 11:42:51 UTC (about 21 years ago)
The more correct way is to do:
export PKG_CONFIG_PATH=/usr/local/lib/pkgconfig/
Sincerely, Brix
raymond ostertag
2004-03-29 21:20:44 UTC (about 21 years ago)
Install libexif9-devel and then libjpeg62-devel and again until you are OK with the configuration (read carrefully to be sure to have every plugin built).
On MDK9.2 you don't need Contrib or external download or lib compilations, everything is on the 3 GPL cd's, even for python support ( ./configure --enable-python ), but you need to install lot of -devel RPM's not installed by default.
@+ Raymond
