How do I delete to transparency?
How do I delete to transparency? bobdobbs 30 Sep 05:39
  How do I delete to transparency? T?kés Ábel 30 Sep 08:38
  How do I delete to transparency? yahvuu 30 Sep 08:53
   How do I delete to transparency? bobdobbs 02 Oct 02:50
    How do I delete to transparency? yahvuu 05 Oct 14:11
2010-09-30 05:39:41 UTC (almost 15 years ago)
Hi all.
I'd like to delete in such a way that transparency remains.
I've found that this is the default when I'm working on images that I've created myself. But if I'm working on an image that I've downloaded or gotten from another source, I can't predict the behaviour of functions that remove pixels.
In my immediate case, I've got a icon with a white background. I want to remove the background. However, when I try to remove the white pixels, the result is black pixels.
How can I figure out what the result of deletion operations on pixels will be?
How can I consistantly remove colour, leaving transparency?
Thanks.
T?kés Ábel
2010-09-30 08:38:10 UTC (almost 15 years ago)
9/30/2010 5:39 AM keltezéssel, bobdobbs írta:
Hi all.
Thanks.
You have to add alpha channel from the image menubar through Layer ? Transparency ? Add alpha Channel.
http://docs.gimp.org/2.6/en/gimp-layer-alpha-add.html
With an alpha channel, the default operation of eraser is deleting to transparency.
However, if you want to turn white to transparency, you'd better use Colors ? Color to alpha.
Abel
yahvuu
2010-09-30 08:53:05 UTC (almost 15 years ago)
On 30.09.2010 05:39, bobdobbs wrote:
Hi all.
short answer: always add an alpha channel to the layer, either using the layers dialog or via Layers->Transparency->Add Alpha Channel [1].
The alpha channel determines the transparency for each pixel. The absence of an alpha channel means that all pixels are fully opaque and hence they get deleted to background color [2].
regards, peter
[1] http://docs.gimp.org/2.6/en/gimp-layer-alpha-add.html [2] http://docs.gimp.org/2.6/en/gimp-image-combining.html#gimp-layer-properties
2010-10-02 02:50:02 UTC (almost 15 years ago)
I'm foolish.
I should have realised this.
Thank you.
Hi all.
regards,
peter
yahvuu
2010-10-05 14:11:32 UTC (over 14 years ago)
for the record, i just learned that a bold layer name indicates a missing alpha channel (as displayed in the layers dialog): http://docs.gimp.org/2.6/en/gimp-dialogs-structure.html#gimp-layer-dialog
-peter
