How to merge two movies ?
10 of 11 messages available
How to merge two movies ? Julien MOZZICONACCI 25 Mar 17:55
  How to merge two movies ? Sven Neumann 25 Mar 18:45
   GAP [was: How to merge two movies ? ] Gezim Hoxha 26 Mar 00:20
    GAP [was: How to merge two movies ? ] Sven Neumann 26 Mar 01:22
     GAP [was: How to merge two movies ? ] Gezim Hoxha 26 Mar 01:28
      GAP [was: How to merge two movies ? ] Geoffrey 26 Mar 02:34
       GAP [was: How to merge two movies ? ] BandiPat 26 Mar 04:25
   How to merge two movies ? Julien MOZZICONACCI 26 Mar 11:35
pipo@lptl.jussieu.fr 07 Oct 20:16
  How to merge two movies ? Timothy E. Jedlicka - wrk 26 Mar 17:13
   How to merge two movies ? Joao S. O. Bueno 26 Mar 18:20
Julien MOZZICONACCI
2004-03-25 17:55:18 UTC (about 21 years ago)
Hi all,
I have two sets of a hundred of images wich can be converted into two movies. I would like two make only one movie, that is to play those two movies at the same time.
I hope that I am clear enough.
Does someone know if I can do that with Gimp ?
Pipo.
2004-03-25 18:45:36 UTC (about 21 years ago)
Julien MOZZICONACCI writes:
Actually, no. I don't think you explained what you want to achieve.
GAP, the GIMP Animation Package could be what you are looking for.
Gezim Hoxha
2004-03-26 00:20:28 UTC (about 21 years ago)
Does this GAP thing have an option to export as .swf? This, I could really use.
Do you Yahoo!?
Yahoo! Finance Tax Center - File online. File on time.
http://taxes.yahoo.com/filing.html
2004-03-26 01:22:08 UTC (about 21 years ago)
Gezim Hoxha writes:
No. And since shockwave flash is mainly a vector animation file format, GIMP is not the tool you want to use to create or edit those.
Gezim Hoxha
2004-03-26 01:28:35 UTC (about 21 years ago)
.swf?
Yeah, you're right. But is there any tool that does this at this point in time for linux. It could be very simple, as long as it exports .swf . BTW, f4l doesn't do it.
-Gezim
Do you Yahoo!?
Geoffrey
2004-03-26 02:34:08 UTC (about 21 years ago)
.swf?
Openoffice will export to flash.
BandiPat
2004-03-26 04:25:18 UTC (about 21 years ago)
On Thursday 25 March 2004 08:34 pm, Geoffrey wrote:
.swf?
And won't Inkscape & Sodipodi do vector graphics? Inkscape being the better of the two available for Linux right now.
Patrick
Julien MOZZICONACCI
2004-03-26 11:35:28 UTC (about 21 years ago)
Hi all,
Thank you for your answer, I will try to make my point clearer. I have two sets of one hundred frames (Frame1_0001 .... Frame1_0100 and Frame2_0001 .... Frame2_0100). I can make two distinct movies with those frames. I want to do only one movie of a hundred frames with each frame Frame12_xxxx being a juxtaposition of Frame1_xxxx and Frame2_xxxx. That is two say that I wish to create only one movie composed of the two other ones playing simultanously.
I hope that I succeded in being clear.
Best regards.
Julien.
2004-03-26 17:13:06 UTC (about 21 years ago)
(whoops - sorry gimpers, responded to the wrong note)
For merging two movies - you may want to check out "blender", don't know if it does what your after, but looks like it might.
http://www.blender.org/ -----
Timothy Jedlicka, bonzo@lucent.com, 1-630-713-4436, AOL-IM=bonzowork Network Entomologist, Lucent Technologies, Testers For Hire
Joao S. O. Bueno
2004-03-26 18:20:17 UTC (about 21 years ago)
easier there,
I'd say gimp-gap could do it. Althoiug I have not played ostensively with GIMP-GAP to be that sure. (/me likes "filter all layers" )
If anyone in the knows of GIMP GAP say it can't be done by the functionalities already there, I could write a Python-fu to handle that.
So, people who use/develop gimp-gap, can this merge be done?
