dependant scm files and script-fu load
dependant scm files and script-fu load Alan Campbell 10 Sep 13:43
  dependant scm files and script-fu load Rob Antonishen 10 Sep 15:41
Alan Campbell
2010-09-10 13:43:19 UTC (almost 15 years ago)
I have several scm files; they all live in a single folder (which is on GIMP search path for scripts).
I have common code for three of the scripts which all goes into a fourth. A fifth has defines which user of scripts may wsh to alter; the fourth script depends on it.
If I just leave nature -- or GIMP to take it's course, the scripts don't load when scripts come up, unless I arrange for the most- depended on script (the fifth) to have a name prceeding all others in alphabetical sort order, the fourth the next in order.
If I refresh scripts, name order doesn't seem to matter, all works fine.
Okay, so to avoid problem I'd like to explicitly load one file from another. But (load ) seems to require an absolute path. I don't want to specify absolute path because other users of scripts (which are mean to be distributed) could put scripts anywhere.
Is there a way to refer to something like "folder in which curent script resides" or "user GIMP configuration folder" (e.g. on my machine Docs and Settings\UserName\.gimp-2.6)?
Yrs,
Alan
The more you complain, the longer God lets you live.
Rob Antonishen
2010-09-10 15:41:24 UTC (almost 15 years ago)
gimp-directory gets you to there.
Check out this page: http://www.ve3syb.ca/wiki/doku.php?id=software:sf:writing
-Rob A>
