Importing EPS
1 of 2 messages available
AANLkTi=LwcBV4O9xv1JNn0AmeT... 07 Oct 20:21
  Importing EPS Bob Long 07 Sep 00:57
Bob Long
2010-09-07 00:57:33 UTC (almost 15 years ago)
Importing EPS
JA wrote:
I'm using GIMP 2.6.7 in Windows 7 64-bit. When I try to import an EPS, I get an error message telling me, "Make sure that Ghostscript is installed and - if necessary - use the environment variable GS_PROG to tell GIMP abouit its location."
I've downloaded and installed Ghostscript for 64-bit, but evidently GIMP doesn't know where it is. And I've been unable to find any explanation in the online documentation of where or how one would set environment variables.
I tried adding the Ghostscript folder (in C:/Program Files) to GIMP's Preferences dialog in the Modules, Interpreters, and Environment Folders, and then restarted, but that didn't help. I get the same error message as before.
What steps precisely do I need to take in order to get GIMP to see the Ghostscript installation?
Thanks in advance for any assistance!
A Google search for me for:
+gimp +ghostscript
gives this as the first response:
http://community.contractwebdevelopment.com/install-ghostscript-windows-and-gimp
