Separate+ 0.5.8-beta1
Separate+ 0.5.8-beta1 Yoshinori Yamakawa 28 Aug 11:28
  Separate+ 0.5.8-beta1 Martin Nordholts 28 Aug 11:41
   Separate+ 0.5.8-beta1 Yoshinori Yamakawa 30 Aug 17:59
    Separate+ 0.5.8-beta1 Branko Vukelic 31 Aug 00:07
  Separate+ 0.5.8-beta1 Fairfielder 31 May 20:16
Yoshinori Yamakawa
2010-08-28 11:28:50 UTC (over 14 years ago)
Beta1 of Separate+ 0.5.8 is available.
http://sourceforge.jp/projects/separate-plus/releases/47873/
Changes from 0.5.7 are: - Initial support for Little CMS 2
- Minor design update of the profile selection dialog - Support for exporting (and importing) transparent TIFF file - Bug fixes
To report bugs, visit the ticket page at SourceForge.JP: http://tinyurl.com/2ae6gmg
Please help us to update the message catalogs.
Thanks.
Martin Nordholts
2010-08-28 11:41:17 UTC (over 14 years ago)
Hi Yamakawa-san
What do you think about getting this plug-in into upstream GIMP for GIMP 2.8? Thanks in advance for your comment on this.
Best wishes, Martin
Yoshinori Yamakawa
2010-08-30 17:59:40 UTC (over 14 years ago)
Separate+ is not a simple RGB->CMYK plug-in any longer.
I think we have to remove some features and elements (profile selection widgets, devicelink profile support, icc_colorspace plug-in and so on) if it will be merged into the GIMP 2.8. (However, I do not wish for it so much.)
Branko Vukelic
2010-08-31 00:07:12 UTC (over 14 years ago)
It'd be awesome to have it inside Gimp, though. For one, it'd get more attention from developers that way, and maybe get more features (like UCR/GCR, etc) sooner... At least I hope. :P
But if it doesn't end up being part of Gimp, I'm quite happy with it anyway. :)
2011-05-31 20:16:38 UTC (almost 14 years ago)
When I open a jpg file in GIMP 2.6.1, then select Image -> Separate -> Separate, when I click on the Source Color Space dropdown menu I get a list of files in the default folder for icc files. But when I click on the Destination Color Space menu, no list appears and if try to enter a valid file path for my CMYK destination profile I get an Invalid Profile error message. What am I doing wrong?
Thanks.
