Help with Gimp-help
Help with Gimp-help John Culleton 08 Aug 21:05
  Help with Gimp-help Owen 09 Aug 00:53
   Help with Gimp-help John Culleton 09 Aug 01:33
    Help with Gimp-help Michael Schumacher 09 Aug 10:06
John Culleton
2010-08-08 21:05:29 UTC (over 14 years ago)
Help with Gimp-help
As an occasional user of Gimp I don't have all the arcana of installation memorized. Where can I find gimp-help and where should I install it?
Salackware Linux 13.0, Gimp 2.6.6.
Owen
2010-08-09 00:53:22 UTC (over 14 years ago)
Help with Gimp-help
Hi John,
Have a look at http://www.gimp.org/downloads/ and see if that helps
Look for the bit that says GIMP help files are available at ftp://ftp.gimp.org/pub/gimp/help/
Owen
John Culleton
2010-08-09 01:33:24 UTC (over 14 years ago)
Help with Gimp-help
Hi John,
Owen _______________________________________________ Gimp-user mailing list
It appears that the English version of the help file is corrupted. First I get ftp download errors (binary download) for lines that consist only of a carriage return. I did it twice and got the same message. Next when I try to bunzip2 the file I get
bunzip2: Data integrity error when decompressing. Input file = gimp-help-2.6.0-html-en.tar.bz2, output file = gimp- help-2.6.0-html-en.tar
I can keep trying, but is this a known defect?
2010-08-09 10:06:13 UTC (over 14 years ago)
Help with Gimp-help
Von: John Culleton
No problems here at all. You could try other mirrors and check if you encounter the same problems.
There are currently no know errors with the files on the FTP servers.
Regards, Michael
