Script-fu problem -- how to load an image
Script-fu problem -- how to load an image Norbert Preining 22 Mar 10:25
  Script-fu problem -- how to load an image Sven Neumann 22 Mar 13:47
   Script-fu problem -- how to load an image Norbert Preining 23 Mar 09:01
    Script-fu problem -- how to load an image Norbert Preining 25 Mar 15:32
Norbert Preining
2004-03-22 10:25:25 UTC (about 21 years ago)
Hello!
Gimp version 2.0pre4 (debian/sid gimp1.3 1.3.27+2.0pre4)
I am trying to extend one of my scripts from an old version but cannot get gimp-file-load to work:
Here the script: (define (script-fu-fileload filein)
(gimp-message-set-handler 1)
; Create an img and a layer
(gimp-message "1")
(gimp-message filein)
(set! my-image (gimp-file-load 1 filein filein)) (gimp-message "2"))
(script-fu-register "script-fu-fileload" "/Script-Fu/Norb/fileload"
"Testscript"
"Norbert Preining "
"Norbert Preining"
"2004.03.17"
SF-FILENAME "filein" "./dummy.tiff")
But I cannot get it to run without error: $ gimp --no-data -i --verbose -b '(script-fu-fileload "\"test.tif\"") This is a development version of The GIMP. Debug messages may appear here.
INIT: gimp_load_config Parsing '/etc/gimp/1.3/gimprc'
Parsing '/home/norbert/.gimp-1.3/gimprc' gimp_composite: use=yes, verbose=no
supported by gimp_composite: +mmx +sse -sse2 -3dnow -altivec -vis INIT: gimp_initialize
INIT: gimp_real_initialize
INIT: gimp_restore
INIT: gimp_real_restore
Starting extension: 'extension_script_fu' script-fu: 1
script-fu: "test2.jpg"
batch command: experienced an execution error.
Also, when I give the full pathname to test.tif (which exits) it doesn't work.
No idea why, but maybe someone can help me!
Best wishes and thanks for all your help
Norbert
------------------------------------------------------------------------------- Norbert Preining Technische Universität Wien gpg DSA: 0x09C5B094 fp: 14DF 2E6C 0307 BE6D AD76 A9C0 D2BF 4AA3 09C5 B094 ------------------------------------------------------------------------------- QUERRIN (n.)
A person that no one has ever heard of who unaccountably manages to make a living writing prefaces.
--- Douglas Adams, The Meaning of Liff
2004-03-22 13:47:50 UTC (about 21 years ago)
Norbert Preining writes:
(gimp-message "1")
"Testscript"
"Norbert Preining "
"Norbert Preining"
"2004.03.17"
You need to pass all parameters to your script. You can use the PDB Browser to check how the script is actually registered. GIMP added a run-mode parameter for you. So please try this command-line instead:
gimp --no-data -i --verbose -b '(script-fu-fileload 0 "\"test.tif\"")
Norbert Preining
2004-03-23 09:01:00 UTC (about 21 years ago)
On Mon, 22 Mär 2004, Sven Neumann wrote:
Here the script:
(gimp-message "1")
"Testscript"
"Norbert Preining "
"Norbert Preining"
"2004.03.17"
Same same unfortunately:
$ gimp --no-data -i --verbose -b '(script-fu-fileload 0 "\"test.tif\"")' This is a development version of The GIMP. Debug messages may appear here.
INIT: gimp_restore
So this didn't help, hmm.
Best wishes
Norbert
------------------------------------------------------------------------------- Norbert Preining Technische Universität Wien gpg DSA: 0x09C5B094 fp: 14DF 2E6C 0307 BE6D AD76 A9C0 D2BF 4AA3 09C5 B094 ------------------------------------------------------------------------------- VANCOUVER (n.)
The technical name for one of those huge trucks with whirling brushes on the bottom used to clean streets. --- Douglas Adams, The Meaning of Liff
Norbert Preining
2004-03-25 15:32:11 UTC (about 21 years ago)
Here the script:
(gimp-message "1")
"Testscript"
"Norbert Preining "
"Norbert Preining"
"2004.03.17"
INIT: gimp_restore
I tried with calling the plugin from within gimp UI, and it works without any problem. So I don't see why it doesn't work here. Any more suggestions what I can do? Is there the possibility to make gimp output more debug stuff?
Best wishes
Norbert
------------------------------------------------------------------------------- Norbert Preining Technische Universität Wien gpg DSA: 0x09C5B094 fp: 14DF 2E6C 0307 BE6D AD76 A9C0 D2BF 4AA3 09C5 B094 ------------------------------------------------------------------------------- IBSTOCK (n.)
Anything used to make a noise on a corrugated iron wall or clinker-built fence by dragging it along the surface while walking past it. 'Mr Bennett thoughtfully selected a stout ibstock and left the house.' - Jane Austen, Pride and Prejudice, II. --- Douglas Adams, The Meaning of Liff
