Problems Installing gmic_gimp plug-in
4 of 5 messages available
Problems Installing gmic_gimp plug-in Jeff Trefftzs 06 Jul 19:03
Problems Installing gmic_gimp plug-in Jernej Simon?i? 06 Jul 19:54
  Problems Installing gmic_gimp plug-in Jeff Trefftzs 07 Jul 00:53
   201007071048.06462.tneuer@i... Torsten Neuer 07 Jul 10:48
    Problems Installing gmic_gimp plug-in Jeff Trefftzs 07 Jul 21:21
Jeff Trefftzs
2010-07-06 19:03:30 UTC (almost 15 years ago)
I've just come back to the GIMP after some years absence, but thought I knew what I was doing. However -- I downloaded the gmic_gimp plugin for 64-bit Linux, and installed it (I thought) by unzipping the binary into $HOME/.gimp-2.6/plug-ins. It's there, it's a 64-bit ELF binary, etc. But the GIMP never seems to find it.
So, I tried it again in the global library: /usr/lib64/gimp/2.0/plug-ins. Still no luck. It doesn't show up in the filters menu, nor does it appear in the plug-in browser.
Has anyone gotten this plug-in working?
System: Dual-core Athlon II, OS: Fedora Core 11 (very recent installation). GIIMP: 2.6.8 (came with distro).
Jernej Simon?i?
2010-07-06 19:54:50 UTC (almost 15 years ago)
Make sure it's got executable bit set.
Jeff Trefftzs
2010-07-07 00:53:17 UTC (almost 15 years ago)
-rwxr-xr-x. 1 jeff jeff 2749352 2010-06-30 01:37 gmic_gimp
(From /usr/lib64/gimp/2.0/plug-ins). Executable by everyone.
Any other suggestions?
Jeff Trefftzs
2010-07-07 21:21:00 UTC (almost 15 years ago)
On Wed, 2010-07-07 at 10:48 +0200, Torsten Neuer wrote:
Try open Gimp from the command line. If GMic crashes during initialization, you will most probably see some descriptive error message there.
Thanks, Torsten. That worked. (I was missing fftw). I'll remember to try the command line next time.
