Need a bit of help, 2 layer, need to edit
Need a bit of help, 2 layer, need to edit OneOnTheEdge 02 Jul 19:59
  Need a bit of help, 2 layer, need to edit Branko Vukelic 03 Jul 11:07
  Need a bit of help, 2 layer, need to edit Noel Stoutenburg 03 Jul 19:11
   Need a bit of help, 2 layer, need to edit OneOnTheEdge 04 Jul 00:17
Need a bit of help, 2 layer, need to edit OneOnTheEdge 02 Jul 20:41
2010-07-02 19:59:25 UTC (almost 15 years ago)
Well, you'll recognize me :-) I've learned much, have copied my picture over a background having 2 layers. The picture is semi-transparent, just what I want. But the picture has a small part I need to either cut, clear, or somehow get rid of. All I can manage to do is Free Select and draw around what I want to cut but when I cut the image actually gets more bold and clear. What am I missing? Thanks....
2010-07-02 20:41:29 UTC (almost 15 years ago)
Branko Vukelic
2010-07-03 11:07:49 UTC (almost 15 years ago)
I'm not sure what you mean by "bold and clear". Usually "clear" is a good thing, but you don't seem to like your "clear". :)
Anyway, try this method:
http://www.brankovukelic.com/post/526945497/effective-background-extraciton-gimp
Also, when using selection to erase parts of an image, you can control the softness of the edge by using Select > Feather.
Noel Stoutenburg
2010-07-03 19:11:34 UTC (almost 15 years ago)
Sounds to me like you are only applying the selection to one layer. Make your selection, and perform your cut; then, in the layer dialog, select successive layers without moving the selection, and cut the same part out of each layer.
Alternatively, if the entire image is as you want it to be, and you have no need for maintaining the separate layers, merge the layers together, and then make your cut.
ns
2010-07-04 00:17:54 UTC (almost 15 years ago)
Neil, your suggestion made sense and worked perfectly. I actually had 5 layers, when I pasted the pic onto the background it was too light so I copied again, added to the depth, so I ended up doing this 4 times and got just the right look. So, I needed to cut 4 times, then used smudge to blend. Thanks for the help guys.......
