How is 16 bit GIMP doing?
13 of 13 messages available
How is 16 bit GIMP doing? Ken Warner 21 Jun 17:18
  How is 16 bit GIMP doing? Alexandre Prokoudine 21 Jun 17:31
   How is 16 bit GIMP doing? Martin Nordholts 21 Jun 18:49
    How is 16 bit GIMP doing? John Culleton 21 Jun 19:57
     How is 16 bit GIMP doing? Branko Vukelic 21 Jun 20:06
      How is 16 bit GIMP doing? Alexandre Prokoudine 21 Jun 21:53
       How is 16 bit GIMP doing? Branko Vukelic 21 Jun 22:03
        How is 16 bit GIMP doing? Alexandre Prokoudine 21 Jun 22:12
         How is 16 bit GIMP doing? Branko Vukelic 21 Jun 23:10
     How is 16 bit GIMP doing? Martin Nordholts 21 Jun 20:06
      How is 16 bit GIMP doing? John Culleton 12 Jul 14:58
       How is 16 bit GIMP doing? Alexandre Prokoudine 12 Jul 15:16
       How is 16 bit GIMP doing? Carusoswi 14 Jul 02:52
Ken Warner
2010-06-21 17:18:06 UTC (almost 15 years ago)
Is it still being worked on? If so, is there any word on availability?
2010-06-21 17:31:03 UTC (almost 15 years ago)
"When it's ready" is the best you can get :)
Martin Nordholts
2010-06-21 18:49:00 UTC (almost 15 years ago)
There is more to say.
Right now the top priority is to get GIMP 2.8 released. The current goal is late 2010. GIMP 2.8 does not have support for high bit depths.
Once GIMP 2.8 is out, we will start phasing out the legacy 8-bit-per-channel code and replace it with GEGL. In other words, we will start for real to introduce support for high bit depths in GIMP. There is no schedule of this work, so a date cannot be given. It is reasonable though to expect this work to go on for say 2-4 years.
Regards, Martin
John Culleton
2010-06-21 19:57:32 UTC (almost 15 years ago)
current goal
we will
There
reasonable
Regards, Martin
And what is the priority/schedule for CMYK?
Branko Vukelic
2010-06-21 20:06:23 UTC (almost 15 years ago)
I think 2-4 years is more than enough for CMYK (hopefully).
Meanwhile, give separate+ a go. It gets the job done, and very reliable. Latest version supports clipping paths, and saving to CMYK TIFF, JPEG, and PSD. I'm not sure about reading those files back into Gimp, but I think it was mentioned somewhere it can be done. I've never needed to do it myself, though, so you're on your own.
I've given an overview of the color management in Gimp and part of it covers basic separate+ usage:
http://www.brankovukelic.com/post/513356271/gimp-color-management-for-dtp
Martin Nordholts
2010-06-21 20:06:48 UTC (almost 15 years ago)
We know we need CMYK sooner or later, but higher bit depths and non-destructiveness is much more important. So first good support for the latter, then we can begin looking into proper support for the former IMO. Maybe in a stable version 6-8 years from now with the current pace of development.
/ Martin
2010-06-21 21:53:04 UTC (almost 15 years ago)
Or CMYKTool
Branko Vukelic
2010-06-21 22:03:22 UTC (almost 15 years ago)
Or CMYKTool
Prokudine,
Veering a bit OT now, I've tried to use CMYKTool, and got an impression it was a bit redundant for separate+ users. Does it have anything to add (or do anything differently)?
2010-06-21 22:12:18 UTC (almost 15 years ago)
Or CMYKTool
Prokudine,
Vukelic? :)
Well, if you *have* used CMYKTool, you couldn't possibly fail to notice the big thing called live soft proof or the small thing called displaying per-channel ink density value for the point under mouse pointer (right below the big thing) :-) Or how CMYKTool allows creating CMYK files in a color-unmanaged way, which is also desirable in some cases (implemented by a request, in fact).
I don't see how either of them make the other one redundant. Wise people use both, depending on what they are trying to achieve.
Branko Vukelic
2010-06-21 23:10:47 UTC (almost 15 years ago)
Or CMYKTool
Prokudine,
Vukelic? :)
Sure.
I will take your advice to heart, oh wise one! :)
John Culleton
2010-07-12 14:58:45 UTC (almost 15 years ago)
depths and
good support for
for the former
the current pace
of development.
/ Martin
Hey, I may not live that long :
2010-07-12 15:16:09 UTC (almost 15 years ago)
The debate on what ID lifted and what it didn't will never stop, eh?
There seems to be a recently growing trend to solve GIMP's bottlenecks by introducing external plug-ins that do some fancy stuff and run in 16bpc mode, e.g.:
http://www.mm-log.com/blog/2010-07-09/adaptive-saturation-curve-labcurves
You might like getting Mike to code quick patch-ups, no?
Of course, mating the goat and the wilber would be preferable.
2010-07-14 02:52:49 UTC (almost 15 years ago)
/ Martin
Well, this January marks a chronological milestone for me, and, at this stage, six to eight years seems like something close to a life sentence for me. I guess I need to resign my open source editing sights for long-term (for me) 8-bit. I do like version 7.1 very much, though.
Keep up the good work.
Caruso
