Biggest Frustration
29 of 29 messages available
Biggest Frustration Steve VanSlyck 21 Jun 17:16
  Biggest Frustration Alexandre Prokoudine 21 Jun 17:39
   Biggest Frustration yahvuu 21 Jun 22:03
    Biggest Frustration R Kimber 21 Jun 22:54
     Biggest Frustration Alexandre Prokoudine 22 Jun 00:11
    Biggest Frustration Branko Vukelic 21 Jun 23:08
    Biggest Frustration Alexandre Prokoudine 22 Jun 00:30
     Biggest Frustration Branko Vukelic 22 Jun 00:36
     Biggest Frustration yahvuu 22 Jun 17:55
      Biggest Frustration Alexandre Prokoudine 22 Jun 18:42
       Biggest Frustration yahvuu 22 Jun 19:05
        Biggest Frustration Branko Vukelic 22 Jun 20:02
        Biggest Frustration Alexandre Prokoudine 22 Jun 20:58
      Biggest Frustration Sven Neumann 22 Jun 20:27
       Biggest Frustration yahvuu 22 Jun 21:08
        Biggest Frustration Branko Vukelic 22 Jun 21:12
         Biggest Frustration yahvuu 22 Jun 21:23
          Biggest Frustration Branko Vukelic 22 Jun 21:26
           Biggest Frustration yahvuu 22 Jun 21:46
            Biggest Frustration Alexandre Prokoudine 22 Jun 21:50
             Biggest Frustration yahvuu 22 Jun 22:05
              Biggest Frustration Alexandre Prokoudine 22 Jun 22:36
               Biggest Frustration Branko Vukelic 22 Jun 22:39
            Biggest Frustration Branko Vukelic 22 Jun 21:58
        Biggest Frustration Alexandre Prokoudine 22 Jun 21:47
         Biggest Frustration yahvuu 22 Jun 21:59
          Biggest Frustration Branko Vukelic 22 Jun 22:04
  Biggest Frustration Martin Nordholts 21 Jun 18:45
   Biggest Frustration Branko Vukelic 21 Jun 19:14
Steve VanSlyck
2010-06-21 17:16:22 UTC (almost 15 years ago)
Biggest Frustration
My biggest frustration with GIMP is the complete lack of a general object selection tool. Not having an "arrow" tool is counter intuitive to the way we've been taught since the Faraday saw the first semiconductor claw its way into visibility in 1833.
2010-06-21 17:39:34 UTC (almost 15 years ago)
Biggest Frustration
My biggest frustration is that _I_ haven't been studying bitmap graphics tools since 1833, you lucky bugger! I envy, envy, envy you!
The only reason I don't commit suicide out of being jealous is because I know difference between vector graphics and bitmap graphics and therefore I can use Inkscape for dealing with objects and you can't :-) Oh, wait -- you can. Just try it :-)
Martin Nordholts
2010-06-21 18:45:20 UTC (almost 15 years ago)
Biggest Frustration
There is a specification for such a tool: http://gui.gimp.org/index.php/Transformation_tool_specification
Someone just needs to write the code. We won't have time to do that for 2.8 though.
/ Martin
Branko Vukelic
2010-06-21 19:14:21 UTC (almost 15 years ago)
Biggest Frustration
Oh no! Now I'm gonna kill myself! :))))
yahvuu
2010-06-21 22:03:54 UTC (almost 15 years ago)
Biggest Frustration
Hey Alexandre,
hopefully this doesn't compromise your health, but an object picker has already been proposed (which is my fault) [1], and for good reason:
If you take non-destructive editing serious, you inevitably end up with a finer granularity of adjustability than with the current scheme -- hence objects [2]. This is not my fault, but GEGL's. Should also produce a little relief for those poor little abused layers ;-)
Nobody is allowed to die until GIMP is finished! - yahvuu
[1] http://gimp-brainstorm.blogspot.com/2009/06/object-picker.html [2] http://gimp-brainstorm.blogspot.com/2009/06/objects-within-layers.html
R Kimber
2010-06-21 22:54:10 UTC (almost 15 years ago)
Biggest Frustration
and it natively uses all those free 8bf plugins!
- Richard
Branko Vukelic
2010-06-21 23:08:35 UTC (almost 15 years ago)
Biggest Frustration
Unless it's of old age! :D (No offence, developers.)
2010-06-22 00:11:09 UTC (almost 15 years ago)
Biggest Frustration
Speaking of which, if we manage to finally get Adobe to publish PSD spec (they promised to do it soon), maybe we can get them to publish plug-ins spec. Not that it will come bundled with a free developer to do all the dirty job in PSPI, mind you :)
2010-06-22 00:30:24 UTC (almost 15 years ago)
Biggest Frustration
On 6/22/10, yahvuu wrote:
Hey Alexandre,
Well, it looks like slightly improved existing Move tool to me :)
Branko Vukelic
2010-06-22 00:36:25 UTC (almost 15 years ago)
Biggest Frustration
Hey Alexandre,
I'd add it wouldn't make a lot of sense without vastly improved vector paths tool. Otherwise it's much better and simpler to have layer groups and "objects" on different layers.
yahvuu
2010-06-22 17:55:45 UTC (almost 15 years ago)
Biggest Frustration
Actually, i was thinking of a pure object selection tool without any manipulation functionality. Just to choose the current paint context without obscuring it, and without having to resort to the layers dialog. Somewhat paradoxically, this would be my favourite tool for color adjustments.
regards, yahvuu
2010-06-22 18:42:43 UTC (almost 15 years ago)
Biggest Frustration
In the times of transformation tools to be merged and some selection tools to be merged as well a tool for just selection sounds a bit limiting, don't you think? :)
For what color adjustments precisely?
yahvuu
2010-06-22 19:05:24 UTC (almost 15 years ago)
Biggest Frustration
not limiting, but liberating ;)
An object picker nicely complements the unified transformation tool. Using the latter to select objects is like taking the sledgehammer to crack a nut: it takes quite some attention to select without accidentally moving things and additionally, the transform tool's handle will obscure parts of the target.
anything from the 'Color' menu as well as filters. An object picker might also be regarded as a 'Menu target selection tool'.
You are right though, that peter is striving hard to cut down the tool count... - yahvuu
Branko Vukelic
2010-06-22 20:02:47 UTC (almost 15 years ago)
Biggest Frustration
Don't you think it'd be much better if tools that work on object would simply do the selection if you, say Alt-click or Ctrl-click an object with it? Also, a Photoshop-like approach of Alt-right-clicking to open a menu of all objects/layers that are below the cursor. You don't need a tool dedicated to the purpose.
2010-06-22 20:27:30 UTC (almost 15 years ago)
Biggest Frustration
And why does the Move tool not work for you then? It allows you to select a layer simply by clicking into the image. Perhaps you missed the "Set layer or path as active" option in the Preferences dialog?
2010-06-22 20:58:57 UTC (almost 15 years ago)
Biggest Frustration
Did anybody suggest that? :)
And again, why don't you just use the Move tool? It works exactly like the picker and it does *not* move anything until you tell it to.
yahvuu
2010-06-22 21:08:35 UTC (almost 15 years ago)
Biggest Frustration
No, the problem with the move tool is that it requires attention to select a layer without accidentally moving it. You really have to stop the mouse and keep it fixed while clicking. Or did i miss some other option?
regards, yahvuu
Branko Vukelic
2010-06-22 21:12:53 UTC (almost 15 years ago)
Biggest Frustration
I use Gimp with a tablet. And you know how tablets are. There's no way you can stop the cursor in place. But the move tool still doesn't accidentally move stuff around for me. And I don't think I've got some serious mouse-fu...
yahvuu
2010-06-22 21:23:52 UTC (almost 15 years ago)
Biggest Frustration
well, possibly it's just me (and i'm not too fond of mice, anyway). I actually trained myself to activate the rectangle selection tool while doing color adjustments -- after struggling with a serious of images which contained miraculously slightly off-moved layers...
regards, yahvuu
Branko Vukelic
2010-06-22 21:26:27 UTC (almost 15 years ago)
Biggest Frustration
Wasn't it easier to just use the layers palette?
yahvuu
2010-06-22 21:46:18 UTC (almost 15 years ago)
Biggest Frustration
thanks, but i refuse to select layers by their thumbnails in the layers dialog, when i can just click them right there in image! .-)
With one hand on the keyboard, tools can be switched quite fast..
thanks anyway, yahvuu
2010-06-22 21:47:38 UTC (almost 15 years ago)
Biggest Frustration
There is no such problem. Look at the tool's options palette. The default mode is to select, not move.
2010-06-22 21:50:27 UTC (almost 15 years ago)
Biggest Frustration
That is, you refuse to work on images with layers completely overlapping other layers? :)
Branko Vukelic
2010-06-22 21:58:10 UTC (almost 15 years ago)
Biggest Frustration
You can disable the dispay of thumbnails. :))))
With the... move tool. :)
yahvuu
2010-06-22 21:59:17 UTC (almost 15 years ago)
Biggest Frustration
that gives hope, it's just that i can't reproduce...
The active options reads "Pick a layer or guide", but when i start dragging, the freshly picked layer gets moved.
The Preferences option given by Sven determines wether a picked and or moved layer will be activated after the operation but doesn't change anything else. At least that's the behaviour i'm used too (and just checked).
now i'm really astonished, yahvuu
(running git master from last week on kubuntu, in case that matters...)
Branko Vukelic
2010-06-22 22:04:29 UTC (almost 15 years ago)
Biggest Frustration
Don't drag. That's the whole point. I've done some crude testing just now, and you have to move the mouse like you really mean it in order to have the drag registered. So your mouse might be too fast or something or too low-resolution. Try to lower the speed of your mouse a bit and see if that helps.
yahvuu
2010-06-22 22:05:16 UTC (almost 15 years ago)
Biggest Frustration
quoting myself:
>> when i *can* just click them right there in image!
as a sidenode, it's indeed an interesting question why completely overlapping layers get stacked. Probably quite some cases of 'layer abuse' can be found in such images.
But let's get this thread closed gracefully :_)
regards, yahvuu
2010-06-22 22:36:01 UTC (almost 15 years ago)
Biggest Frustration
Of for god's sake, blending modes weren't invented for nothing :)
Branko Vukelic
2010-06-22 22:39:19 UTC (almost 15 years ago)
Biggest Frustration
Or layer masks.
