RAW film formats.
RAW film formats. John Culleton 18 Jun 18:23
  RAW film formats. John Mills 18 Jun 19:32
   RAW film formats. John Culleton 18 Jun 22:18
    RAW film formats. Branko Vukelic 18 Jun 22:24
    RAW film formats. John Mills 19 Jun 23:34
John Culleton
2010-06-18 18:23:05 UTC (almost 15 years ago)
RAW film formats.
While cruising through Krita I note that it will import several raw digital formats from several camera manufacturers. Will this be a Gimp feature in the future?
John Mills
2010-06-18 19:32:34 UTC (almost 15 years ago)
RAW film formats.
Try the 'ufraw' plugin. See:
[http://ufraw.sourceforge.net]
Works here.
- Mills
John Culleton
2010-06-18 22:18:45 UTC (almost 15 years ago)
RAW film formats.
Works here.
- Mills
raw
be a
Very good. The specific Krita filter that caught my eye was for "Fuji RAF raw image." There were about a dozen others for various makes of cameras. Does the existing Gimp filter cover all these variants?
Branko Vukelic
2010-06-18 22:24:36 UTC (almost 15 years ago)
RAW film formats.
Last I've heard, Krita's raw format support was based on dcraw, which is what ufraw uses. So, basically, they should support the same formats.
John Mills
2010-06-19 23:34:50 UTC (almost 15 years ago)
RAW film formats.
You'll have to check for yourself. I use it with Pentax DSLR raw and I recall it accepts others but I only looked as far as the camera I have.
- Mills
Works here.
raw
be a
