Error: Blend Does Not Operate On Index Layer
Error: Blend Does Not Operate On Index Layer Tristen 08 Jun 02:24
  Error: Blend Does Not Operate On Index Layer Tristen 08 Jun 02:26
  Error: Blend Does Not Operate On Index Layer Jozef Legény 08 Jun 11:49
2010-06-08 02:24:08 UTC (almost 15 years ago)
I just got this message now. I did the thing I want to do two days ago. Now I got this message. i need a way t fix it that is easy and simple to follow.
2010-06-08 02:26:24 UTC (almost 15 years ago)
This is for the text I am making.
Jozef Legény
2010-06-08 11:49:36 UTC (almost 15 years ago)
Many color operations do not work on the Indexed images, due to the limitations induced by the palette.
What you need to do is to transform the image to use the RGB colorspace. To do this open your image and in the menu use Image -> Mode -> RGB
Also note that GIF images are indexed by default, so in order to use color operations with gifs you need to work with a xcf file and then export the final image.
Cheers Jozef
-- Tristen (via www.gimpusers.com)
