Mouse Click Coordinates
8 of 8 messages available
Mouse Click Coordinates Kevin Myers 13 Mar 08:27
  Mouse Click Coordinates Sven Neumann 13 Mar 12:04
   Mouse Click Coordinates Alexander Rabtchevich 13 Mar 12:27
    Mouse Click Coordinates Sven Neumann 13 Mar 12:58
     Mouse Click Coordinates Alexander Rabtchevich 13 Mar 13:26
Mouse Click Coordinates Kevin Myers 13 Mar 12:09
  Mouse Click Coordinates Sven Neumann 13 Mar 12:52
  Mouse Click Coordinates David Neary 13 Mar 13:04
Kevin Myers
2004-03-13 08:27:02 UTC (about 21 years ago)
Is there any way that I can write a GIMP add-in that can obtain the coordinates of user mouse clicks in the main GIMP image window? My add-in needs the user to be able to click on specific locations within the main image window in order to obtain various coordinates for subsequent processing.
Thanks, s/KAM
2004-03-13 12:04:27 UTC (about 21 years ago)
"Kevin Myers" writes:
No, there isn't. All you can do is to show a representation of the image in the plug-in dialog and have the user click there.
Kevin Myers
2004-03-13 12:09:05 UTC (about 21 years ago)
Sven, you're the guru, so you would know. However, how is it that I can't get the coordinates, when apparantly something like the crop tool can? Is the crop tool specially written using internal gimp facilities that aren't available to a normal add-in?
Thanks again, s/KAM
----- Original Message ---
2004-03-13 12:27:43 UTC (about 21 years ago)
I have another question - is it possible through settings to make GIMP to display the size of rectangular selection, excluding non-image area? Current realization displays the size of the whole selection, even if the part of the selection is outside image boundaries.
If it's impossible, should I fill an issue?
2004-03-13 12:52:53 UTC (about 21 years ago)
Would you mind to define "normal add-in" then? I assumed you meant a plug-in and the crop tool, like all other tools, is completely implemented in the core.
2004-03-13 12:58:27 UTC (about 21 years ago)
Alexander Rabtchevich writes:
The selection cannot extend the image boundaries. This is a bug in the rectangular selection tool then.
David Neary
2004-03-13 13:04:08 UTC (about 21 years ago)
Hi Kevin,
This is the difference between a tool and a plug-in. A tool is something which (usually) operates locally on the basis of a mouse click (the colour tools are the exceptions, which often causes some confusion). A plug-in usually gets a copy of a drawable to work on, and doesn't have access to things like mouse click events which are captured and treated in the core.
Cheers, Dave.
2004-03-13 13:26:21 UTC (about 21 years ago)
Ok, I've posted a bug.
