HELP Using 2.6.6- Brushes are just spots!
HELP Using 2.6.6- Brushes are just spots! firebelly 21 May 05:47
  HELP Using 2.6.6- Brushes are just spots! firebelly 21 May 06:11
   HELP Using 2.6.6- Brushes are just spots! Olivier Lecarme 21 May 07:52
   HELP Using 2.6.6- Brushes are just spots! Branko Vukelic 21 May 13:45
2010-05-21 05:47:01 UTC (almost 15 years ago)
I just downloaded GIMP 2.6.6. I am trying to get some work done in it, however, any time I try to use a brush, pencil, eraser, pretty much anything, I just get boxes, spotting, and straight lines. I can not seem to get a circle. I was going to do some portrait work with this, but I am not able to if it will only give me boxes. Does anyone know what could be causing this? I have been using Photoshop, but I wanted to try something different. I know that this can be fixed, does anyone know how? Please help! Thank you.
2010-05-21 06:11:24 UTC (almost 15 years ago)
http://i22.photobucket.com/albums/b302/pixy333/grrrr.jpg this is a link to a sample of what the brush does. This doesn't show the squaring off, but is shows the dotting. It should be one continuous line.
Olivier Lecarme
2010-05-21 07:52:59 UTC (almost 15 years ago)
You are using a 3x3 brush and scaling it five times. Better select a 15x15 fuzzy round brush at scale 1.
Branko Vukelic
2010-05-21 13:45:48 UTC (almost 15 years ago)
Also check the spacing slider below the brush selection palette. It's a percentage of the individual brush mark's size that defines the distance between individual marks. For instance, spacing of 150% for a 3px brush means that individual brush marks will be left on canvas every 4.5px (so you get a 1.5px gap between brush marks).
-- Kelley (via www.gimpusers.com)
