A bunch of questions
A bunch of questions ortaconic 20 May 23:20
  A bunch of questions Noel Stoutenburg 21 May 00:16
   A bunch of questions Rob Antonishen 22 May 15:28
   A bunch of questions ortaconic 24 May 20:20
2010-05-20 23:20:54 UTC (about 15 years ago)
Hey folks!
I've got a small mess of questions, and I do not mind being redirected to older threads. :)
Here goes:
If I have a bunch of text layers, how do I reselect them to move them and/or edit their content without moving backwards in the history?
Also, I have a smudge brush effect currently behind a text layer. The brush effect was a long time before the text layer. I need to remove the brush effect. How do I do so without going backwards in the history, thus eliminating the text (and any other previous work on the project after the smudge tool was used)?
Is there any way to save projects "in progress" to continue editing later, with the history intact?
Finally, though, This is the second time this has occurred. The project will be moving along nicely, then suddenly none of the tools work. Everything is still clickable and the screen does not freeze or crash, but I can do no more work on the project.
Has anyone heard of this happening and is there any way around it?
Thanks a bunch!
Noel Stoutenburg
2010-05-21 00:16:17 UTC (about 15 years ago)
Adam wrote:
Hey folks!
Here goes:
This will only work if you haven't merged the text dialog into another layer, even another text layer: in the layers dialog, make the layer with the bit of text you want to edit the active layer, and click on the text to open the text dialog. Note that in a layer dialog, only the text is in the layer, so if you are using a font with a large size, you might have to click exactly on a character of the text.
Activate the layers dialog, select the layer with the brush effect, and delete it. Of course, if there is other content in the layer that contains the brush effect you want to eliminate, that will be deleted, too.
I know that saving an image as an ~.xcf file will preserve the layers. I've never tried to save a file with an intact history, so I may be wrong, but I'm not sure you can save a file with the history intact. I've never tried to do this, because I've never needed to, since my standard workflow method is that when I work on a highly complex image, where I anticipate that I might want to have access to the history, I create this history by incremental back-ups; that is, after I have layer 1 the way I want it, I save the work, then when I get layer 2 the way I want it, I make second a back-up with a different name, and when I get layer 3 the way I want it, I make a backup with a name distinct from the first two.
Rob Antonishen
2010-05-22 15:28:30 UTC (about 15 years ago)
Regarding backups I wrote a script http://registry.gimp.org/node/14246 that makes a backup xcf file with the same name and date plus time appended. If you bind it to a key (that is what I do) it is very quick to save a working copy every now and then.
-Rob A>
On 5/20/10, Noel Stoutenburg wrote:
Adam wrote:
Hey folks!
Here goes:
2010-05-24 20:20:41 UTC (about 15 years ago)
That's just it, though. I thought so, too, but the xcf file I saved only kept the text layers intact. Everything else that was done has been lumped together into a "background" layer, and thus I cannot seem to access the other layers to delete.
I have, after many headaches already, adopted a similar workflow. :) Though it is rather annoying in my creative process, I hope it will help, too. Thanks!
