building pre4 on Mandrake 9.2
building pre4 on Mandrake 9.2 Thomas Spuhler 08 Mar 19:34
  building pre4 on Mandrake 9.2 Sven Neumann 08 Mar 20:08
   building pre4 on Mandrake 9.2 Thomas Spuhler 08 Mar 20:34
   building pre4 on Mandrake 9.2 Thomas Spuhler 10 Mar 00:01
    building pre4 on Mandrake 9.2 Sven Neumann 10 Mar 01:48
     building pre4 on Mandrake 9.2 Thomas Spuhler 11 Mar 18:04
Thomas Spuhler
2004-03-08 19:34:40 UTC (about 21 years ago)
I am trying to build an rpm on Mandrake 9.2 but get the following major errors:
+ exit 0
Processing files: gimp-devel-2.0pre4-1 error: File not found by glob: /home/international/rpmbuild/tmp/gimp-2.0pre4-root/usr/lib/*.so error: File not found by glob: /home/international/rpmbuild/tmp/gimp-2.0pre4-root/usr/lib/*.a error: File not found by glob: /home/international/rpmbuild/tmp/gimp-2.0pre4-root/usr/lib/gimp/1.3/modules/*.a Processing files: gimp-docs-2.0pre4-1 Finding Provides: /usr/lib/rpm/filter.sh ' ' /usr/lib/rpm/find-provides Using BuildRoot: /home/international/rpmbuild/tmp/gimp-2.0pre4-root to search libs Finding Requires: /usr/lib/rpm/filter.sh ' ' /usr/lib/rpm/find-requires /home/international/rpmbuild/tmp/gimp-2.0pre4-root i586 Requires(rpmlib): rpmlib(PayloadFilesHavePrefix)
Where do I get this rmplib from? I tried to search but w/o luck
2004-03-08 20:08:16 UTC (about 21 years ago)
Thomas Spuhler writes:
Are you trying to use the included spec file? That is not going to work, it is Fedora specific. You will need to use a spec file for Mandrake.
And don't expect the gimp.spec file from the pre-releases to be in the final 2.0 tarball. It will most likely not be there.
Thomas Spuhler
2004-03-08 20:34:18 UTC (about 21 years ago)
Yes, that is what I did. I changed the requires to the Mandrake names
Does anybody have a working Mandrake spec file?
Sven _______________________________________________ Gimp-user mailing list
Thomas Spuhler
2004-03-10 00:01:12 UTC (about 21 years ago)
I spent some time on this and I think I got it working. The rpm and srpm were built after I corrected the filenames towards the end of the spec file (in the files section). I would be surprised if it worked on Fedora. The filenames the make created were just different from the ones in the files section of the spec file.
2004-03-10 01:48:59 UTC (about 21 years ago)
Can you be more specific about the changes you had to do or perhaps post a diff or the modified spec file here? It would be nice to have this accessible from the mailing list archives.
Thomas Spuhler
2004-03-11 18:04:10 UTC (about 21 years ago)
I think I was a little quick saying that the RPM build worked. Some of the needed files were not built ( they in fact were not in the lib directory where as about 10 others were. I'll work on it over the weekend.
;echo RESULT=$? error: Failed dependencies:
lcms is needed by gimp-2.0pre4-1
libgimp-1.3.27 is needed by gimp-2.0pre4-1 libgimp-1.3.so.24 is needed by gimp-2.0pre4-1 libgimpbase-1.3.27 is needed by gimp-2.0pre4-1 libgimpbase-1.3.so.24 is needed by gimp-2.0pre4-1 libgimpcolor-1.3.27 is needed by gimp-2.0pre4-1 libgimpcolor-1.3.so.24 is needed by gimp-2.0pre4-1 libgimpmath-1.3.27 is needed by gimp-2.0pre4-1 libgimpmath-1.3.so.24 is needed by gimp-2.0pre4-1 libgimpmodule-1.3.27 is needed by gimp-2.0pre4-1 libgimpmodule-1.3.so.24 is needed by gimp-2.0pre4-1 libgimpthumb-1.3.27 is needed by gimp-2.0pre4-1 libgimpui-1.3.27 is needed by gimp-2.0pre4-1 libgimpwidgets-1.3.27 is needed by gimp-2.0pre4-1 libgimpwidgets-1.3.so.24 is needed by gimp-2.0pre4-1
