gimp-2.0pre4 and python-fu "Drop Shadow and Bevel" plugin
gimp-2.0pre4 and python-fu "Drop Shadow and Bevel" plugin Tom Williams 07 Mar 20:38
  gimp-2.0pre4 and python-fu "Drop Shadow and Bevel" plugin Simon Budig 07 Mar 20:57
   gimp-2.0pre4 and python-fu "Drop Shadow and Bevel" plugin Tom Williams 07 Mar 21:21
    gimp-2.0pre4 and python-fu "Drop Shadow and Bevel" plugin Sven Neumann 07 Mar 21:38
Tom Williams
2004-03-07 20:38:13 UTC (about 21 years ago)
So, I'm running gimp-2.0pre4 on Linux and I've got python 2.2.3 and pygtk-2.2.0-RC1 installed. When I try to use the Python-FU "Drop Shadow and Bevel" plugin, I get the dialog allowing me to configure the effect but it doesn't run, due to this error:
Traceback (most recent call last): File "/usr/lib/gimp/1.3/python/gimpfu.py", line 470, in _run res = apply(func, params)
File "/usr/lib/gimp/1.3/plug-ins/shadow_bevel.py", line 7, in shadow_bevel img.undo_group_start(img)
TypeError: undo_group_start() takes no arguments (1 given)
Is there something else I need to update to enable this to work?
Thanks...
Peace...
Tom
Simon Budig
2004-03-07 20:57:04 UTC (about 21 years ago)
It seems the script is broken here. Change that call to img.undo_group_start ()
and it should work.
Hope this helps, Simon
Tom Williams
2004-03-07 21:21:54 UTC (about 21 years ago)
and it should work.
Yup, that did the trick. Thanks. Since this script came with gimp-2.0pre4, will this be fixed in the gimp distribution before 2.0 is released?
Peace...
Tom
2004-03-07 21:38:15 UTC (about 21 years ago)
Tom Williams writes:
Only if you file a bug-report for it.
