Advanced Rounded Rectangle
Advanced Rounded Rectangle DrGeezle 17 Mar 21:02
  Advanced Rounded Rectangle Alexandre Prokoudine 17 Mar 21:28
2010-03-17 21:02:35 UTC (over 15 years ago)
The dialog for the Advanced Rounded Rectangle has me confused. What data am I supposed to enter and what is a horizontal or vertical radius ?
2010-03-17 21:28:36 UTC (over 15 years ago)
Where did you find this function? I only see "Select > Rounded Rectangle" menu items and it surely doesn't have hor/vert radius
Pixels would be most likely choice.
If your curiosity brought you a little further ;-), you'd play with options and see that it is a distance of points, from which each corner is rounded, from original corners. E.g. if you want a rectangular that is almost like an ellipse, you define a large horizontal radius and small vertical radius, so that rounding stretches a lot horizontally and very little vertically.
See http://tavmjong.free.fr/INKSCAPE/MANUAL/html/Shapes-Rectangles.html for examples.
Alexandre
