Edit Zoom ratios?
Edit Zoom ratios? 127markaz 14 Mar 15:28
  Edit Zoom ratios? David Gowers 14 Mar 23:50
  Edit Zoom ratios? Sven Neumann 15 Mar 08:20
2010-03-14 15:28:04 UTC (almost 15 years ago)
Edit Zoom ratios?
I do a lot of picture rendering and find myself zooming images to ratios of 3:1 and 6:1 (300% and 600%, respectively) for a majority of jobs. Can these be added to the popup menu at the bottom of the window instead of having to manually enter these values each time via View > Zoom > Other?
Thank you very much.
markaz
David Gowers
2010-03-14 23:50:49 UTC (almost 15 years ago)
Edit Zoom ratios?
For 300%, isn't it easier just to hit 2, +? In any case, while it would be a good enhancement to be able to customize zooming, you should not *need* to use View->Zoom->Other. Just highlight the first character in the popup (assuming the popup says something like '800%'), type 6, hit Enter. No dialog required.
David
2010-03-15 08:20:56 UTC (almost 15 years ago)
Edit Zoom ratios?
You can enter the value directly in the entry at the bottom of the image window. And if you do that once, it will add itself to the popup of that image window.
