2.0 and OSX
2.0 and OSX Jonathan Chetwynd 23 Feb 22:35
  2.0 and OSX Simon Budig 23 Feb 23:07
Jonathan Chetwynd
2004-02-23 22:35:53 UTC (almost 21 years ago)
2.0 and OSX
am I dreaming or is all this talk of a 2.0 version going to end up with an osX version that uses SVG format?
someone pinch me before I drop off the perch.
thanks
Jonathan Chetwynd http://www.peepo.co.uk
"It's easy to use"
Simon Budig
2004-02-23 23:07:59 UTC (almost 21 years ago)
2.0 and OSX
Maybe you should rephrase your question, especially I don't know what "talk" you are referring to. Rumours, damn rumours and statistics?
There will be a 2.0 version, yes. And it can be run on osX, yes, although it uses an X-Server. And yes, there is support for reading SVG images, but this implies rasterizing the vector data into pixels. Paths can be ex- and imported via SVG, but this doesn't make Gimp an SVG editing application.
Hope this helps, Simon
