Pressure sensitivity works and then stops 80 |O
4 of 5 messages available
Pressure sensitivity works and then stops 80 |O Zaug 23 Feb 21:37
  Pressure sensitivity works and then stops 80 |O Sven Neumann 24 Feb 11:15
zaug@zaug.netmegs.com 07 Oct 20:16
  Pressure sensitivity works and then stops 80 |O Timothy E. Jedlicka - wrk 25 Feb 23:34
   Pressure sensitivity works and then stops 80 |O Joao S. O. Bueno 26 Feb 13:29
Zaug
2004-02-23 21:37:47 UTC (over 21 years ago)
I am using a wacom serial tablet on SuSE 9 under KDE 3.1.4. The pressure sensitivity works when I first start the gimp, 1.2.5, but stops working after an arbitrary amount of time. Restarting gimp does not remedy the problem. I have tried to pin it down to a particular action, but have had no luck reproducing the situation on demand. I have also done lots of google searching, searching of the wacom project mailing list, and have had little luck there either. I have tried using gimp 1.3 as well but it does not even recognize the tablet. Is there something different about the way this is handled from 1.2 ?
I read bugs 81663,127680,115774 & 120133 but none of them address this directly.
I am using the wacom input module that is included with X. I tried a couple of versions from the linux wacom project but could not get it working with them; would only move the cursors no mouse click events. Tried many different configuration options, including the one where the wacom devices each have two entries with different settings. I get no X-session errors that I can identify as being related to this. I realize that this may not be a problem with gimp itself but I thought that the people on this list have probably had the most experience with this sort of thing and would at least have some ideas where to go or what to try next. Lastly, one for you long time wacom users; it is a used tablet and stylus, is this possibly a symptom of a hardware issue; what sort of things happen when a stylus starts to malfunction ?
I am about out on this so ANY suggestions would be appreciated.
Thank you for any help, Zaug
2004-02-24 11:15:50 UTC (over 21 years ago)
Zaug writes:
No, but just as with gtk+-1.2, you need to explicitely enable support for XInput when compiling gtk+-2.x. If GTK+ doesn't have XInput support, GIMP won't see the tablet.
2004-02-25 23:34:55 UTC (over 21 years ago)
On Mon, 23 Feb 2004, "Zaug" == Zaug wrote:
Zaug> I am using a wacom serial tablet on SuSE 9 under KDE 3.1.4. The Zaug> pressure sensitivity works when I first start the gimp, 1.2.5, but Zaug> stops working after an arbitrary amount of time.
I see the same behavior with my wacom tablet. Likewise I can't find any error footprint - nothing seems to complain. I've gone to mostly using the eraser - it seems to work reliably. I'm using Gimp2.0pre3 BTW. -----
Timothy Jedlicka, bonzo@lucent.com, 1-630-713-4436, AOL-IM=bonzowork Network Entomologist, Lucent Technologies, Testers For Hire
Joao S. O. Bueno
2004-02-26 13:29:04 UTC (over 21 years ago)
Could both of you proceed to bugzilla.gimp.org and report that? I mean, if it is not reported already - search for other bugs wich might be related first.
Thank you,
JS ->
Timothy E. Jedlicka - wrk escreveu:
