Fwd: Re: Need help: "correcting" exposures in time-lapse imagesets
3 of 5 messages available
Need help: "correcting" exposures in time-lapse imagesets ckin 08 Feb 05:17
  Need help: "correcting" exposures in time-lapse imagesets saulgoode@flashingtwelve.brickfilms.com 08 Feb 20:29
   Need help: "correcting" exposures in time-lapse imagesets ckin 09 Feb 09:49
    201002100029.15493.daniel.h... Daniel Hornung 10 Feb 00:29
     201002102013.20000.daniel.h... Daniel Hornung 10 Feb 20:13
2010-02-08 05:17:08 UTC (over 15 years ago)
Hi, my son and I are doing a science project in which we're measuring dye transport
in plant leaves over time. Using a Canon Powershot A40 and Canon's RemoteCapture app to
snap images every 60 seconds.
Unfortunately, through RemoteCapture you can set film speed, but shutter speed
remains in Auto mode. In order to digitally compare each image with the initial
reference image (to determine the amount of dye absorbed), the exposures need
to be the same each time.
Is there a way to compensate for exposure time in a relatively accurate way, say,
see each image as if it were shot in 1/20 sec? I wish I could use the CHDK package,
but the A40 doesn't seem to be supported.
Regards, kinata
2010-02-08 20:29:45 UTC (over 15 years ago)
Quoting kinata :
Hi, my son and I are doing a science project in which we're measuring dye transport in plant leaves over time. Using a Canon Powershot A40 and Canon's RemoteCapture app to snap images every 60 seconds.
Unfortunately, through RemoteCapture you can set film speed, but shutter speed remains in Auto mode. In order to digitally compare each image with the initial reference image (to determine the amount of dye absorbed), the exposures need to be the same each time.
Is flash mode available in remote capture? If so, perhaps one could be used to obtain a consistent exposure (no AE, and the "shutter speed" effectively is determined by the flash).
Is there a way to compensate for exposure time in a relatively accurate way, say, see each image as if it were shot in 1/20 sec? I wish I could use the CHDK package, but the A40 doesn't seem to be supported.
Perhaps you could include a test pattern in the frame (ie, place a picture of a test pattern next to the plant) and be able to match exposure settings by adjusting the levels of the images such that the two test patterns match (if this works, it could likely be automated).
2010-02-09 09:49:16 UTC (over 15 years ago)
Saul, thank you, sir...replies follow.
Well, our brainstorm was to use a fluorescent dye, without using a flash. The exposure times range from 1 sec to 1/20 sec, ISO 200, f2.8. This wouldn't represent a showstopper, as we're concentrating on the area of each image that contains pixels having that color of dye. So I just need to iterate through the pixels and count those having a certain threshold of a defined RGB value to get the area of the image containing the dye.
Now I reveal my true ignorance. I was thinking that I could duplicate a layer containing a source image, play with its opacity, and then merge the layer back into the original source image to arrive at a target "exposure". Might that work?
In a related issue posted elsewhere in this forum, I'm wanting to isolate the dye part of the image: -- convert the RGB triple for the dye color (approximately a cyan) to HSB (HSV?) colorspace,
-- rotate it to (say) green, and then -- extract the green layer of the image. This last is probably off-topic...just being conversational.
Kinata
