2.0Pre, rpmbuild does not build on MDK9.2
2.0Pre, rpmbuild does not build on MDK9.2 Thomas Spuhler 16 Feb 15:53
  2.0Pre, rpmbuild does not build on MDK9.2 Sven Neumann 16 Feb 16:03
   2.0Pre, rpmbuild does not build on MDK9.2 Thomas Spuhler 16 Feb 22:13
    2.0Pre, rpmbuild does not build on MDK9.2 Ville Pätsi 16 Feb 22:19
     2.0Pre, rpmbuild does not build on MDK9.2 Thomas Spuhler 16 Feb 22:42
Thomas Spuhler
2004-02-16 15:53:45 UTC (about 21 years ago)
I tried to build an rpm of the 2.0Pre3 but i get quite some errors toward the end. I am missing a lot of files. I think I have all the required libraries, but it seems during the compiling process, some things are missing. I did it two ways: renaming the required packages in the gimp.spec file and also with a --nodeps
It may could be an error in the spec file. Has anybody a spec file that works on Mandrake 9.2?
2004-02-16 16:03:47 UTC (about 21 years ago)
Thomas Spuhler writes:
The spec file included with the tarball is RedHat specific; it won't work for Mandrake. Also, the spec file is not guaranteed to work at all, even on RedHat. It's there for the convenience of Ville only.
Thomas Spuhler
2004-02-16 22:13:38 UTC (about 21 years ago)
I am not so certain that it is the spec file: I may missing a library or something. I get this at the end:
Cleaning files...done Compressing files...done
Stripping files...done
Relativisation of symlinks...done
Clean perl...done
Building libraries symlinks...done
Fixing translations...done
Processing files: gimp-2.0pre3-1
error: File not found:
/var/tmp/gimp-2.0pre3/usr/lib/libgimp-1.3.so.25.0.0 error: File not found: /var/tmp/gimp-2.0pre3/usr/lib/libgimp-1.3.so.25 error: File not found:
/var/tmp/gimp-2.0pre3/usr/lib/libgimpui-1.3.so.25.0.0 error: File not found: /var/tmp/gimp-2.0pre3/usr/lib/libgimpui-1.3.so.25 error: File not found:
/var/tmp/gimp-2.0pre3/usr/lib/libgimpbase-1.3.so.25.0.0 error: File not found:
/var/tmp/gimp-2.0pre3/usr/lib/libgimpbase-1.3.so.25 error: File not found:
/var/tmp/gimp-2.0pre3/usr/lib/libgimpcolor-1.3.so.25.0.0 error: File not found:
/var/tmp/gimp-2.0pre3/usr/lib/libgimpcolor-1.3.so.25 error: File not found:
/var/tmp/gimp-2.0pre3/usr/lib/libgimpmath-1.3.so.25.0.0 error: File not found:
/var/tmp/gimp-2.0pre3/usr/lib/libgimpmath-1.3.so.25 error: File not found:
/var/tmp/gimp-2.0pre3/usr/lib/libgimpmodule-1.3.so.25.0.0 error: File not found:
/var/tmp/gimp-2.0pre3/usr/lib/libgimpmodule-1.3.so.25 error: File not found:
/var/tmp/gimp-2.0pre3/usr/lib/libgimpthumb-1.3.so.25.0.0 error: File not found:
/var/tmp/gimp-2.0pre3/usr/lib/libgimpthumb-1.3.so.25 error: File not found:
/var/tmp/gimp-2.0pre3/usr/lib/libgimpwidgets-1.3.so.25.0.0 error: File not found:
/var/tmp/gimp-2.0pre3/usr/lib/libgimpwidgets-1.3.so.25 Executing(%doc): /bin/sh -e /var/tmp/rpm-tmp.16438 + umask 022
+ cd /home/international/rpmbuild/BUILD + cd gimp-2.0pre3
+ DOCDIR=/var/tmp/gimp-2.0pre3/usr/doc/gimp-2.0pre3 + export DOCDIR
+ rm -rf /var/tmp/gimp-2.0pre3/usr/doc/gimp-2.0pre3 + /bin/mkdir -p /var/tmp/gimp-2.0pre3/usr/doc/gimp-2.0pre3 + cp -pr AUTHORS COPYING ChangeLog MAINTAINERS NEWS README /var/tmp/gimp-2.0pre3/usr/doc/gimp-2.0pre3 + cp -pr docs/keybindings.txt README.i18n README.win32 /var/tmp/gimp-2.0pre3/usr/doc/gimp-2.0pre3 + exit 0
Processing files: gimp-devel-2.0pre3-1 error: File not found by glob: /var/tmp/gimp-2.0pre3/usr/lib/*.so error: File not found by glob: /var/tmp/gimp-2.0pre3/usr/lib/*.a error: File not found by glob:
/var/tmp/gimp-2.0pre3/usr/lib/gimp/1.3/modules/*.a Processing files: gimp-docs-2.0pre3-1 Finding Provides: /usr/lib/rpm/filter.sh ' ' /usr/lib/rpm/find-provides Using BuildRoot: /var/tmp/gimp-2.0pre3 to search libs Finding Requires: /usr/lib/rpm/filter.sh ' ' /usr/lib/rpm/find-requires /var/tmp/gimp-2.0pre3 i586
Requires(rpmlib): rpmlib(PayloadFilesHavePrefix)
RPM build errors: File not found: /var/tmp/gimp-2.0pre3/usr/lib/libgimp-1.3.so.25.0.0 File not found: /var/tmp/gimp-2.0pre3/usr/lib/libgimp-1.3.so.25 File not found:
/var/tmp/gimp-2.0pre3/usr/lib/libgimpui-1.3.so.25.0.0 File not found: /var/tmp/gimp-2.0pre3/usr/lib/libgimpui-1.3.so.25 File not found:
/var/tmp/gimp-2.0pre3/usr/lib/libgimpbase-1.3.so.25.0.0 File not found: /var/tmp/gimp-2.0pre3/usr/lib/libgimpbase-1.3.so.25 File not found:
/var/tmp/gimp-2.0pre3/usr/lib/libgimpcolor-1.3.so.25.0.0 File not found: /var/tmp/gimp-2.0pre3/usr/lib/libgimpcolor-1.3.so.25 File not found:
/var/tmp/gimp-2.0pre3/usr/lib/libgimpmath-1.3.so.25.0.0 File not found: /var/tmp/gimp-2.0pre3/usr/lib/libgimpmath-1.3.so.25 File not found:
/var/tmp/gimp-2.0pre3/usr/lib/libgimpmodule-1.3.so.25.0.0 File not found:
/var/tmp/gimp-2.0pre3/usr/lib/libgimpmodule-1.3.so.25 File not found:
/var/tmp/gimp-2.0pre3/usr/lib/libgimpthumb-1.3.so.25.0.0 File not found: /var/tmp/gimp-2.0pre3/usr/lib/libgimpthumb-1.3.so.25 File not found:
/var/tmp/gimp-2.0pre3/usr/lib/libgimpwidgets-1.3.so.25.0.0 File not found:
/var/tmp/gimp-2.0pre3/usr/lib/libgimpwidgets-1.3.so.25 File not found by glob: /var/tmp/gimp-2.0pre3/usr/lib/*.so File not found by glob: /var/tmp/gimp-2.0pre3/usr/lib/*.a File not found by glob:
Ville Pätsi
2004-02-16 22:19:11 UTC (about 21 years ago)
These 5.4K bytes were from Thomas Spuhler,
The spec file won't work in 2.0pre3 because some elements that it requires were removed. They have been readded after the mistake was realised. The rpm building should work again in 2.0pre4.
Thomas Spuhler
2004-02-16 22:42:47 UTC (about 21 years ago)
Thanks. Is the pre4 out?
