How to crop with defined aspect ratio ???
4 of 5 messages available
How to crop with defined aspect ratio ??? helices 03 Feb 22:52
  How to crop with defined aspect ratio ??? Frank Gore 03 Feb 23:01
  How to crop with defined aspect ratio ??? Akkana Peck 03 Feb 23:17
bdfee97d1002031402o574e982d... 07 Oct 20:20
  How to crop with defined aspect ratio ??? Dave 77459 03 Feb 23:21
helices
2010-02-03 22:52:59 UTC (about 15 years ago)
When I'm editing an image and I want to crop that image so it will print 8x10 or 5x8 or whatever, I'm challenged by adjusting the selection box to exactly the right proportions.
What am I missing?
Best Regards,
Mike
Frank Gore
2010-02-03 23:01:25 UTC (about 15 years ago)
What am I missing?
I usually use the "Canvas Size" option for that, and then reposition the picture within the scaled canvas before clicking "Ok". But it's a bit tough to re-position the picture precisely because it looks so small in the dialog.
I'd love to hear how others do it. I wish there was an interactive selection transform tool that I can use modifier keys with.
Akkana Peck
2010-02-03 23:17:06 UTC (about 15 years ago)
helices writes:
The Crop tool's options includes a checkbox for Fixed: Aspect ratio and a field where you can type in 8:10 or 5:8 or whatever you need.
...Akkana
Dave 77459
2010-02-03 23:21:46 UTC (about 15 years ago)
On Wed, Feb 3, 2010 at 4:02 PM, Dave 77459 wrote:
What am I missing?
Best Regards,
Mike
Mike,
When you select the Crop tool, there is a settings dialog? (I do it from the toolbox).
On the settings dialog, there is a "Fixed" checkbox. Check that, then select "Aspect Ratio" from the drop down to the right of it.
In the box below, enter in 8:10 or 10:8 or 5:8 or 8:5. If you get the wrong one (is it height:width or width:height, I can never remember), you can use the "paper sheets" next to the box to make the selection.
Hope this helps.
Dave
I note that I replied to sender, instead of the list. Culpa mea.
Dave
