How to enhance low resolution graphic for larger modified image ???
helices
2010-01-26 20:49:22 UTC (almost 16 years ago)
I have a simple JPG (108x170 pixels) that I want to use in a larger, higher resolution image that I'm creating. It is a fairly simple black and white drawing -- actually, a light bulb with several curves and angles and straight lines.
Yes, I have expanded it to 1000x1575 pixels. Yes, I've zoomed to 800x, selected non-black pixels and deleted them.
What I have now is almost tolerable; but, I'd like to know alternatives, preferably the simplest, most straight forward method to clean up the jagged edges that are visible.
I will not use it at 1000x1575; but, I need it considerably more detailed than 108x170.
Please, comment and advise.
Best Regards,
Mike
Jay Smith
2010-01-26 20:55:08 UTC (almost 16 years ago)
Best Regards,
Mike
This may be missing the point somehow, but if you used some kind of "outlining" program (followed by a little editing) that creates a vector-based (instead of bitmap based) image, you could then scale to whatever size you want with perfect resolution, and then convert that size to a bitmap format like JPG. If you save the vector version, you can scale-and-save-out to as many sizes as you like.
Back in the day I used Adobe Streamline for this kind of task, but I don't know if that even still exists any more.
Jay
Chris Mohler
2010-01-26 21:33:51 UTC (almost 16 years ago)
I would open Inkscape, import the graphic, then either do a trace or redraw it. Then delete the image, save as SVG, open in GIMP at desired size.
Streamline was for OS 8-9 IIRC, and never got ported to OSX. I use inkscape to do tracing - it works better than the auto-trace feature in Adobe's products anyway (especially on blank-and-white images).
Chris
Akkana Peck
2010-01-27 04:27:31 UTC (almost 16 years ago)
helices writes:
Try this:
- Select by color and click on one of the lines.
- Selection to Path.
- Select None.
- Scale the image up to the desired size.
- Path to selection.
- Fill the selection with black.
It doesn't work for everything, but for a line drawing or solid colored block figure, sometimes you can get amazingly smooth edges that way.
...Akkana
